北京中元泰维供应西门子S120产品
2010/9/14 0:00:00
S120
产品分类:品牌:
6SL3000-0CE15-0AA0 SINAMICS SMART Line reactor for 5KW
6SL3000-0CE21-0AA0 SINAMICS SMART Line reactor for 10KW
6SL3055-0AA00-5BA1 SMC20 Sensor Module for external incremental
encoder:SIN/COS 1Vpp absolute encoder: ENDAT without DRIVE-CLIQ cable
6SL3055-0AA00-5CA0 SMC30 Sensor Module for external encoder(without DRIVE-
CLiQ cable)
6SL3060-4AD00-0AA0 Drive CLiQ cable(0.16m), IP20/20
6SL3060-4AF00-0AA0 Drive CLiQ cable(0.21m), IP20/20
6SL3060-4AH00-0AA0 Drive CLiQ cable(0.26m), IP20/20
6SL3060-4AU00-0AA0 Drive CLiQ cable(0.6m), IP20/20
6SL3100-1AE31-0AA0 SINAMIC Braking Module, 1.5KW
6SL3100-1BE22-5AA0 "SINAMICS pulsed resistor plus, 600V, 15.6OHM
control power
module for voltage monitoring "
6SL3100-1BE31-0AA0 SINAMIC Braking resistor, 1.5KW/100KW
6SL3100-1CE14-0AA0 SINAMIC SCAPACITOR MODULEINPUT: 600 V DC4000 UF
6SL3120-1TE13-0AA0 SINAMIC Single Motor Moudule, 3A/1.6Kw, internal cooling
6SL3120-1TE15-0AA0 SINAMIC Single Motor Moudule, 5A/2.7Kw, internal cooling
6SL3120-1TE21-0AA1 SINAMIC Single Motor Moudule, 9A/4.8Kw, internal cooling
6SL3120-1TE21-8AA1 SINAMIC Single Motor Moudule, 18A/9.7Kw, internal cooling
6SL3120-1TE23-0AA1 SINAMIC Single Motor Moudule, 30A/16Kw, internal cooling
6SL3120-2TE13-0AA0 SINAMIC Double Motor Moudle, 2*3A/1.6Kw, internal cooling
6SL3120-2TE15-0AA0 SINAMIC Double Motor Moudle, 2*5A/2.7Kw, internal cooling
6SL3120-2TE21-0AA0 SINAMIC Double Motor Moudle, 2*9A/4.8Kw, internal cooling
6SL3120-2TE21-8AA0 SINAMIC Double Motor Moudle, 2*18A/9.7Kw, internal cooling
6SL3121-1TE13-0AA0 SINAMIC Single Motor Moudule, 3A/1.6Kw, external cooling
6SL3121-1TE15-0AA0 SINAMIC Single Motor Moudule, 5A/2.7Kw, external cooling
6SL3121-1TE21-0AA0 SINAMIC Single Motor Moudule, 9A/4.8Kw, external cooling
6SL3121-1TE21-8AA0 SINAMIC Single Motor Moudule, 18A/9.7Kw, external cooling
6SL3121-1TE23-0AA0 SINAMIC Single Motor Moudule, 30A/16Kw, external cooling
6SL3121-2TE13-0AA0 SINAMIC Double Motor Moudle, 2*3A/1.6Kw, external cooling
6SL3121-2TE15-0AA0 SINAMIC Double Motor Moudle, 2*5A/2.7Kw, external cooling
6SL3121-2TE21-0AA0 SINAMIC Double Motor Moudle, 2*9A/4.8Kw, external cooling
6SL3121-2TE21-8AA0 SINAMIC Double Motor Moudle, 2*18A/ 7Kw, external cooling
6SL3130-6AE15-0AA0 SINAMICS SMART Line module, 5KW, internal cooling
6SL3130-6AE21-0AA0 SINAMICS SMART Line module, 10KW, internal cooling
6SL3130-7TE21-6AA1 SINAMICS ACTIVE Line module, 16KW, internal cooling
6SL3130-7TE23-6AA1 SINAMICS ACTIVE Line module, 36KW, internal cooling
6SL3131-6AE15-0AA0 SINAMICS SMART Line module, 5KW, external cooling
6SL3131-6AE21-0AA0 SINAMICS SMART Line module, 10KW, external cooling
6SL3131-7TE21-6AA0 SINAMICS ACTIVE Line module, 16KW, external cooling
6SL3131-7TE23-6AA0 SINAMICS ACTIVE Line module, 36KW, external cooling
6SL3162-1AF00-0AA0 SINAMICSSHIELD CONNECTION PLATEFOR 150 MMLINE/MOTOR
MODULES
6SL3162-1AH00-0AA0 SINAMICSSHIELD CONNECTION PLATEFOR 300 MMLINE/MOTOR
MODULES
6SL3162-1AH01-0AA0 SINAMICSSHIELD CONNECTION PLATEFOR 200 MMLINE/MOTOR
MODULES
6SL3162-2AA00-0AA0 SINAMICS24 V TERMINAL ADAPTERFOR MODULES IN BOOKSIZE
DESIGN
6SL3162-2BD00-0AA0 SINAMICSDC LINK RECTIFIER ADAPTERFOR DIRECT INFEEDSCREW
TERMINALS 0.5-10 MM2FOR 50 AND 100 MMLINE/MOTOR MODULESIN BOOKSIZE FORMAT
6SL3162-2BM00-0AA0 SINAMICSDC LINK RECTIFIER ADAPTERFOR DIRECT INFEEDSCREW
TERMINALS 35-95 MM2FOR 150, 200 AND 300 MMLINE/MOTOR MODULESIN BOOKSIZE FORMAT
6SL3162-2BM01-0AA0 SINAMICSDC LINK ADAPTERFOR MULTI-TIER DESIGNSCREW
TERMINALS 35-95 SQMMFOR ALLLINE/MOTOR MODULESIN BOOKSIZE FORMAT
6SL3166-3AB00-0AA0 SINAMICSWARNING LABELSFOR SINAMICS MODULEIN BOOKSIZE
DESIGN1 SHEET, 12 LANGUAGES
CLiQ cable)
control power
MODULES
MODULES
MODULES
DESIGN
西门子风机6SY7000-0AB28
西门子安全继电器
西门子 S120变频器
传动进口备件-6SY7000 6SY7010
西门子 伺服模块 6SN1123-1AA00-0EA2
