IPC-BX7102
Robust, Fanless Box PC with Intel Pentium M Platform
盒式工控机IPC-BX7102
无风扇设计
宽幅直流电源输入
加固防震动设计
丰富的载板I/O接口,PCI × 2
易安装维护
系统
CPU Support Intel Celeron M/Pentium processor up to 1.8GHz
with 400MHz FSB
Memory 2 x 240-pin DDRII DIMM 400MHz up to 2GB
Chipset Intel 910GMLE + ICH6M
Graphics Integrated with Intel Graphics Media Accelerator (GMA900)
ATA 1 x Serial ATA ports with 150MB/s HDD transfer rate
1 x 44-pin IDE interface, support UDMA33 IDE device
LAN Chipset 2 x Realtek RTL8111C 10/100/1000Base-T Gigabit Ethernet
WatchdogTimer 1~255 level reset
输入/输出接口
Serial Port 1 x DB44 female connector
Support 4 x RS-232 ports + 1 x 4-bit GPIO 2 in/2 out
(1 x RS-422/485 port shared with COM2)
USB Port 6 x USB 2.0 ports
LAN 2 x RJ45 ports for GbE
KB/MS 1 x 6-pin Mini-DIN for Keyboard and Mouse
Video Port 1 x DB15 female connector for Analog Output
Selectable Port Either of DVI or digital I/O or LPT
DVI-D: Female connector for Digital Video Output
Digital I/O: 12-bit, 6 in/6 out
LPT: SPP/EPP/ECP mode
Audio
Expansion Bus 2 x PCI slot w/ riser card
1 x Mini-card slot
环境
Operating Temp. -20 ~ 55°C (-4 ~ 131°F), ambient w/ air flow
Storage Temp. -40 ~ 85°C (-40 ~ 185°F)
Relative Humidity 10 ~ 95% @ 40°C (non-condensing)
Vibration
MIL-STD-810F, Method 514.5, Procedure 1, Category 4
Shock & Crash
Operating 20G (11ms), Non-operating 40G with HDD
Operating 40G (11ms), Non-Operationg 60G with CF/SSD
Crash 80G (11ms)
认证
CertificationCE, FCC
电源
Power Input DC 10V~28V input (w/ 4-pin DC input terminal block
combine remote power on/off switch)
Power Consumption 50W (Max.)
存储
Type 1 x 2.5" drive bay for HDD/SDD
1 x CompactFlash Type II socket
结构
Construction Aluminum alloy
Mounting Support wall-mounting
Weight 4.24 kg (9.33 lb)
Dimensions (Wx D x H) 195 x 268 x 100 mm (7.68" x 10.55" x 3.93")
