关键字: | 艾讯宏达,G41芯片组,Mini-ITX,4串 |
产品分类: | 工控机 |
品牌: | 艾讯宏达 |
- 产品简介:
- ·LGA775 for Core 2 Duo/Pentium D/Celeron processor ·Intel G41 + ICH7, FSB 800/1066MHz ·2 x 240pin DIMM DDR3 800/1066 up to 4GB ·2 x Realtek RTL8111E PCI-E Giga LAN ·4 x COM ports,8 x USB2.0 ·1 x PCI slot Expansion
>> SYSTEM
Processor LGA775 for Core 2 Duo/Pentium D/Celeron processor
Chipset Intel G41 + ICH7, FSB 800/1066MHz
DRAM 2 x 240PIN DIMM DDR3 800/1066 max up to 4GB
BIOS 8Mb AMI Flash ROM
Power Supply 1 x 20Pin ATX power connector, support AT/ATX mode
Watchdog Watchdog timer function
Dimension 170mm x 170mm
>> I/O Ports
HDD 2 x SATA-300 Interface
Serial Port 4 x COM ports, (3*RS232, 1*RS232/422/485)
Parallel 1 x Parallel pin-header
Audio Realtek ALC662 HD audio codec, support 5.1CH audio
Keyboard/Mouse 2 x PS/2 for Keyboard and Mouse
LAN 2 x Realtek RTL8111E PCI-E Gigabit Lan
USB 8 x USB2.0 (4 by onboard header)
Digital I/O 4 input; 4 output
Expansion 1 x PCI slot Expansion
>> Display
Graphics Intel GMA X4500 up to 512MB video memory
VGA 2048 x 1536 maximum resolution
>> Environment
Operation Temperature 0°~60°C
Humidity 10~90%
更多内容请访问 艾讯宏达科技有限公司(http://c.gongkong.com/?cid=1434)
