CSM07-AT
7" Intel AtomTM Portable Tablet PC with Resistive Touch Screen, Bluetooth, WLAN, RFID and Battery
强固式桌面型电脑 CSM07-AT
7" 宽幅Matrix TFT屏
EN60601-1/EN60601-1-2/UL60601-1 认证
超薄(30mm 厚, (超轻1kg)
低电源功耗
多种接口(蓝牙/无线局域网/RFID/1 × 千兆网)
超可靠性/IP54等级外壳
即时恢复(暂存于Disk/RAM)
超长电池寿命(4 小时)
系统
CPU Intel Atom™ Z510 CPU 1.1GHz FSB 400MHz
Graphics
Controller
Intel Poulsbo included, Advanced Low Power Graphics
supporting 3.0 shadder and texture
Memory DDRII-667 1GB soldered onboard
Chipset Intel System Controller Hub US15W
BIOS AMI BIOS
Audio Azalia HD Audio Codec ALC888-GR
Ethernet Realtek RTL8111B 10/100/1000Base-T
Storage 1 x Industrial Compact Flash 4GB (default)
1 x 1.8" IDE PATA 60GB Slim HDD (optional)
Camera 1 x 1.3 megapixel CMOS Camera w/Mic (front)
1 x 2.0 megapixel CMOS Camera w/o Mic (back)
Connectivity WLAN 802.11 b/g/n support (built-in by USB interface)
Bluetooth 2.0 + EDR support (USB interface)
HSUPA (3.75G) support (optional)
RFID ISO 15693/14443A/14443B RFID support
(distance: 3~5cm; speed: 5 cards/sec)
输入/输出接口
Serial Port 1 x RS-232 port
USB Port 2 x USB 2.0 ports
LAN 1 x RJ-45 GbE LAN
Power Input 1 x Power Jack
Docking
Connection
1 x 35-pin pogo board for connection with docking station
SIM Socket 1 x SIM socket (located underneath the battery pack)
开关与提示
LED Indicator 5 x LEDs on front panel (Power, Storage/Battery/RFID/
Bluetooth)
Function Key
8 programmable function keys on front panel (brightness
up and down, volume up and down, mute on/off, bluetooth
on/off, WiFi on/off, touchscreen on/off)
Power Button 1 x Power on/off switch on the top right
1 x Reset switch on the bottom right
LCD 显示与触摸屏
Display
7" wide active matrix TFT, 1024 x 600 resistive touch
panel with Stylus by USB interface (outdoor readable
optional)
Brightness 350 cd/m²
Contrast 400 : 1
Backlight Type LED
电源系统
Adapter
Power input: AC 100~240V
Power output: 20VDC
Output Rating: 90W
Battery Li-lon Battery Pack 4S1P 2600mA for Battery Life 4 hrs,
ACPC support
机构与环境
Operating Temp. 0 ~ 45°C (32 ~ 113°F)
Storage Humidity 5 to 95% (non-condensing)
Dimensions
(W x D x H)
210 x 36 x 160 mm (8.26" x 1.42" x 6.29")
Gross Weight 1 kg (2.2 lb)
Vibration 1 grms/ 5 ~ 500Hz/ random operation
Shock 10G peak acceleration (11 msec. duration)
Transit Drop 122cm (4 feet) drop to wood, 5 sides all pass, except the
front panel side
IP Rating IP54 compliant
CertificationCE/FCC Class B/EN60601-1-1/EN60601-1-2/UL60601-1
订货信息
CSM07-AT-CF7" tablet PC with Intel Atom™ Z510 1.1GHz, 4GB CF,
90W power adapter
CSM07-AT-HDD 7" tablet PC with Intel Atom™ Z510 1.1GHz, 1.8" 60GB
IDE HDD, 90W power adapter
CSM07-ATS-CF 7" tablet PC with Intel Atom™ Z510 1.1GHz, 4GB CF,
90W power adapter, outdoor readable touch screen
CSM07-ATS-HDD
IDE HDD, 90W power adapter, outdoor readable touch
screen
DTC-0710 Docking station with 1 x RJ-45 Giga LAN, 2 x USB 2.0,
1 x VGA, 2 x RS-232, 1 x DC-in, 2 x charging bays
PAC-M090W 90WAC/DC medical grade adapter and power cord kit
BAT-0710 Battery pack kit
HSUPA-0710
MiniCard HSUPA (3.75G) module supporting WCDMA,
HSUPA, HSDPA & E-GPRS, Triband HSDPA/UMTS (850,
1900, 2100 MHz), Quadband EDGE/GPRS/GSM (850,
