CSM17-AT
17" Fanless Intel AtomTM N270 1.6GHz Panel PC
强固式桌面型电脑CSM17-AT
Bedside Entertainment, Infotainment Applicable
低功耗板载Intel AtomTM N270 1.6GHz CPU
被动冷却系统(无风扇)
无缝前面板,易于清理
无孔设计,满足IP54规范,前面板符合IP65防水防尘
多接口(蓝牙/无线网/千兆有线网)
整合AC97电话,200万像素射像头,RFID, 2D Barcode
MSR和Smart 卡扫描读卡器
系统
CPU Intel Atom™ N270 1.6GHz, FSB 533MHz/512K L2 Cache
Graphics Controller Intel 945GSE
Memory 1 x 200-pin DDRII 667MHz SO-DIMM 1GB (Up to 2GB)
Chipset Intel 945GSE + ICH7M
Serial ATA 1 x Serial ATA 150MB/s HDD transfer rate
Storage 1 x 2.5" SATA HDD 160G installed
部件与设备
Serial Port 1 x RS-232 port
USB Port 2 x USB 2.0 ports
RJ11 2 x RJ11 connectors for AC97 phone
AC97 Phone 1 x AC97 phone
Camera 1 x 2.0 megapixel CMOS camera
RFID 13.56MHz RFID Reader with ISO 15693 support
Connectivity 1 x Intel WG82574L GbE LAN
WLAN 802.11 b/g/n support
1 x Bluetooth module (USB interface)
Barcode Scanner 1 x 2D Barcode Scanner
MSR 1 x Magnetic Strip Reader
Smart Card Reader 1 x Smart Card Reader
TV Card IR, TV tuner designed in, support analog TV (PCI-E slot
(optional)
开关
Buttons 1 x system power on/off button
6 x programmable function keys (Volumn, Brightness,
Phone on/off, Menu)
音频
Codec/Interface Azalia HD Audio Codec (ALC888)
Internal 2 x speakers (1.5W), Microphone built-in
1 x Mic-in,1 x speaker-out
LCD 显示
Size/Type 17" TFT Color LCD/1 Channel 24-bit LVDS
Max.Resolution 1280 x 1024, SXGA
Max. Colors 16.7M colors
Luminance 300 cd/m²
Viewing Angle 70 (H/R), 70 (H/L), 70 (V/U), 70 (V/D) (CR=10)
Contrast Ratio 1000 : 1
Backlight MTBF 40,000 hours
触摸屏
Type 5 wire, Analog Resistive
Light Transparency 80%
Controller Interface USB Interface
电源适配器
Adapter AC Input: 100 ~ 240VAC (Full Range)
DC Output: 60W (Max.), 3.16A/19V
机构与环境
Operating Temp. 0 ~ 45°C (32 ~ 113°F)
Operating Humidity 10 ~ 95% (non-condensing)
Dimensions (Wx Dx H) 406 x 55 x 340 mm (15.98" x 2.17" x 13.39")
Vibration 1 grms/ 5 ~ 500Hz/ random operation
Shock 10G/peak (11ms)
Construction Plastic
Mounting Wall-mount, Ceiling ARM (VESA-75/100)
IP Rating Whole set IP54, front panel IP65 splashproof, dust
resistant
Regulatory CE, FCC class-B, EN60601-1, EN60601-1-2, UL60601-1
