CSP17-COH
17" Intel CoreTM 2 Duo Industrial Panel PC
人机界面 CSP17-COH
支持Intel CoreTM 2 Duo/Celeron M Processor
17" 1280 × 1024 SXGA 彩色TFT LCD 显示
可选面框式样
可选电阻式触摸屏或钢化玻璃
多个扩展接口(5 × USB/1 × Mini PCI/1 × CF)
前面框带USB接口
紧凑设计
系统
CPU Support Intel Core™2 Duo processor with 800MHz FSB
Support Intel Celeron M processor with 533/667MHz FSB
Memory 1 x 200-pin DDR2 SO-DIMM 533/667MHz up to 2GB
Chipset Intel GME965 + ICH8M
LAN 2 x Realtek RTL8111B 10/100/1000 base-T
Watchdog Timer 255-level reset
存储
HDD/Type 1 x 2.5" drive bay for IDE or SATA HDD/SSD
Flash Disk 1 x CompactFlash Type II socket
LCD 显示
Size/Type 17" TFT LCD
Resolution 1280 x 1024, SXGA
Pixel Pitch 0.264 x 0.264 mm
Max. Colors 16.2M (24-bit)
Luminance 300 cd/m²
触摸屏
Type 5-wire, Analog Resistive
(P1772-1200-P, P1772-1200-C only)
Resolution Continuous
Light Transparency 80%
Interface USB Interface
电源
Requirement DC 10 ~ 30V
Consumption 5.76A/12V
输入/输出接口
Serial Port 2 x RS-232 ports
USB Port Front: 1 x USB 2.0 port (for panel-mounting type only)
Bottom: 4 x USB 2.0 ports
KB/MS 1 x 6-pin Mini-DIN connector for Keyboard and Mouse
(PS/2 standard via Y-cable)
LAN 2 x RJ45
VGA 1 x DB15 female connector
Audio Mic-in/Line-in/Line-out
Expansion Bus 1 x Mini PCI socket
机构
Mounting Type Panel-mounting or chassis-mounting (Standard VESA)
Tempered Glass 3 mm (P1772-1100-P, P1772-1100-C only)
Construction Steel (w/ aluminum bezel for panel-mounting type)
Dimension
(W x D x H)
Chassis-mounting type:
405 x 75 x 332 mm (15.94" x 2.95" x 13.07")
Panel-mounting type:
440 x 80 x 360 mm (17.32" x 3.15" x 14.17")
环境
Operating Temp. 0 ~ 50°C (32 ~ 122°F)
Storage Temp. -20 ~ 80°C (-4 ~ 176°F)
Operating Humidity 10 ~ 95% RH @40°C (non-condensing)
Vibration 5~500Hz, 1Grms
订货信息
CSP17-COH-1100-P/
CM550
17" panel-mounting panel PC with tempered glass,
Intel CM550 2.0GHz CPU, 1GB DDR2 SDRAM
CSP17-COH-1200-P/
CM550
17" panel-mounting panel PC with resistive touch
screen, Intel CM550 2.0GHz CPU, 1GB DDR2 SDRAM
CSP17-COH-1100-C/
CM550
17" chassis-mounting panel PC with tempered glass,
CSP17-COH-1200-C/
CM550
17" chassis-mounting panel PC with resistive touch
PAC-P120W 120WAC/DC adapter kit
人机界面 CSP17-COH
