CSP15-AT
15" Fanless Intel AtomTM N270 Industrial Panel PC
人机界面CSP15-AT
超低电压Intel AtomTM N270 CPU
15" 1024 × 768 XGA 彩色TFT LCD 显示
可选面框式样
可选电阻式触摸屏或钢化玻璃
多个扩展接口(3 × USB/1 × Mini PCI/1 × CF)
前面框带USB接口
被动冷却系统(无风扇)
系统
CPU Onboard Intel Atom™ N270 1.6GHz CPU with
533MHz FSB
Memory 1 x 200-pin DDRII SO-DIMM 400/533MHz up to 2GB
Chipset Intel 945GSE + ICH7M
SATA 2.5" drive bay for IDE or SATA HDD/SSD
LAN 2 x Realtek RTL8111C 10/100/1000 base-T
Watchdog Timer 255-level reset
存储
HDD/Type 1 x 2.5" drive bay for HDD or SSD
Flash Disk 1 x CompactFlash Type II socket
LCD 显示
Size/Type 15" TFT LCD
Max. Resolution 1024 x 768, XGA
Pixel Pitch 0.297 x 0.297 mm
Max. Colors 262K (18-bit)
Luminance 260 cd/m²
触摸屏
Type 8-wire, Analog Resistive (P1573-1200-P only)
5-wire, Analog Resistive (P1573-1200-C only)
Resolution Continuous
Light Transparency 80%
Interface USB Interface
电源
Power Input DC 10 ~ 30V
Consumption 2.56A/12V
输入/输出接口
Serial Port 2 x RS-232 ports
USB Port Front: 1 x USB 2.0 port (for panel-mounting type only)
Bottom: 2 x USB 2.0 ports
KB/MS 1 x 6-pin Mini-DIN connector for Keyboard and Mouse
(PS/2 standard via Y-cable)
LAN 2 x RJ45
VGA 1 x DB15 female connector
Audio Mic-in/Line-in/Line-out
Expansion Bus 1 x Mini PCI socket
机构
Mounting Type Panel-mounting or chassis-mounting (Standard VESA)
Tempered Glass 3 mm (P1573-1100-P, P1573-1100-C only)
Construction Steel (w/ aluminum bezel for panel-mounting type)
Dimension
(W x D x H)
Chassis-mounting:
372 x 70.3 x 287 mm (14.65" x 2.77" x 11.3")
Panel-mounting:
390 x 68 x 310 mm (15.35" x 2.68" x 12.2")
环境
Operating Temp. 0 ~ 50°C (32 ~ 122°F)
Storage Temp. -20 ~ 80°C (-4 ~ 176°F)
Operating Humidity 10 ~ 95% RH @40°C (non-condensing)
Vibration 5~500Hz, 1Grms
订货信息
CSP15-AT-1100-P 15" panel-mounting panel PC with tempered glass,
Intel Atom™ N270 CPU, 1GB DDR2 SDRAM
CSP15-AT-1200-P 15" panel-mounting panel PC with resistive touch
screen, Intel Atom™ N270 CPU, 1GB DDR2 SDRAM
CSP15-AT-1100-C 15" chassis-mounting panel PC with tempered glass,
CSP15-AT-1200-C 15" chassis-mounting panel PC with resistive touch
PAC-P065W 65WAC/DC adapter kit
人机界面CSP15-AT
