产品选型
CONTEC康泰克CSP15-COH
CONTEC康泰克CSP15-COH
CSP15-COH 15" Intel CoreTM 2 Duo Industrial Panel PC 人机界面 CSP15-COH 支持Intel CoreTM 2 Duo/Celeron M Processor 15" 1024 × 768 XGA 彩色TFT LCD 显示 可选面框式样 可选电阻式触摸屏或钢化玻璃 多个扩展接口(5 × USB/1 × Mini PCI/1 × CF) 前面框带USB接口 紧凑设计
产品分类:
品牌:
康泰克
CSP15-COH
人机界面 CSP15-COH
可选面框式样
可选电阻式触摸屏或钢化玻璃
前面框带USB接口
紧凑设计
系统
CPU Support Intel Core™2 Duo processor with 800MHz FSB
Support Intel Celeron M processor with 533/667MHz FSB
Memory 1 x 200-pin DDR2 SO-DIMM 533/667MHz up to 2GB
Chipset Intel GME965 + ICH8M
LAN 2 x Realtek RTL8111B 10/100/1000 base-T
Watchdog Timer 255-level reset
存储
HDD/Type 1 x 2.5" drive bay for IDE or SATA HDD/SSD
Flash Disk 1 x CompactFlash Type II socket
LCD 显示
Size/Type 15" TFT LCD
Resolution 1024 x 768, XGA
Pixel Pitch 0.297 x 0.297 mm
Max. Colors 16.2M (24-bit)
Luminance 260 cd/m²
触摸屏
Type 8-wire, Analog Resistive (P1572-1200-P only)
5-wire, Analog Resistive (P1572-1200-C only)
Resolution Continuous
Light Transparency 80%
Interface USB Interface
电源
Requirement DC 10 ~ 30V
Consumption 4.52A/12V
输入/输出接口
Serial Port 2 x RS-232 ports
USB Port Front: 1 x USB 2.0 port (for panel-mounting type only)
Bottom: 4 x USB 2.0 ports
KB/MS 1 x 6-pin Mini-DIN connector for Keyboard and Mouse
(PS/2 standard via Y-cable)
LAN 2 x RJ45
VGA 1 x DB15 female connector
Audio Mic-in/Line-in/Line-out
Expansion Bus 1 x Mini PCI socket
机构
Mounting Type Panel-mounting or chassis-mounting (Standard VESA)
Tempered Glass 3 mm (P1572-1100-P, P1572-1100-C only)
Construction Steel (w/ aluminum bezel for panel-mounting type)
Dimension
(W x D x H)
Chassis-mounting type:
372 x 70.3 x 287 mm (14.65" x 2.77" x 11.3")
Panel-mounting type:
390 x 68 x 310 mm (15.35" x 2.68" x 12.2")
环境
Operating Temp. 0 ~ 50°C (32 ~ 122°F)
Storage Temp. -20 ~ 80°C (-4 ~ 176°F)
Operating Humidity 10 ~ 95% RH @40°C (non-condensing)
Vibration 5~500Hz, 1Grms
订货信息
CSP15-COH-1100-P/
CM550
15" panel-mounting panel PC with tempered glass,
Intel CM550 2.0GHz CPU, 1GB DDR2 SDRAM
CSP15-COH-1200-P/
CM550
15" panel-mounting panel PC with resistive touch
screen, Intel CM550 2.0GHz CPU, 1GB DDR2 SDRAM
CSP15-COH-1100-C/
CM550
15" chassis-mounting panel PC with tempered glass,
CSP15-COH-1200-C/
CM550
15" chassis-mounting panel PC with resistive touch
PAC-P065W 65WAC/DC adapter kit
人机界面 CSP15-COH
工业物联网“CONPROSYS™ M2M网关系列”支持楼宇自动化通信协议“BACnet”
 工业用计算机的基础知识( 四 )  (显示器接口)
康泰克最新推出 - 采用新散热技术将工作温度范围扩展了多达40%的 大功率无风扇嵌入式PC“盒式计算机 BX-M2510”
工业用计算机的基础知识( 三)  (扩展插槽)
边缘计算 / 工业用计算机的基础知识(一) (CPU/芯片组)
