产品选型
CONTEC康泰克CSP12-CM
CONTEC康泰克CSP12-CM
CSP12-CM 12.1" Intel Celeron M 1.0GHz Industrial Panel PC 人机界面 CSP12-CM 超低电压Intel Celeron M CPU 12.1" 800 × 600 SVGA 彩色TFT LCD 显示 可选面框式样 可选电阻式触摸屏或钢化玻璃 多个扩展接口(5 × USB/1 × Mini PCI/1 × CF) 前面框带USB接口 紧凑设计
产品分类:
品牌:
康泰克
CSP12-CM
人机界面 CSP12-CM
可选面框式样
可选电阻式触摸屏或钢化玻璃
前面框带USB接口
紧凑设计
系统
CPU Onboard Intel Celeron M 1.0GHz CPU zero cache
processor with 400MHz FSB
Memory 1 x 200-pin DDR SO-DIMM 200/266MHz up to 1GB
Chipset Intel 852GM + ICH4
LAN 1 x Intel 82562ET 10/100 base-T
Watchdog Timer 255-level reset
存储
HDD/Type 1 x 2.5" drive bay for IDE HDD/SSD
Flash Disk 1 x CompactFlash Type II socket
LCD 显示
Size/Type 12.1" TFT LCD
Resolution 800 x 600, SVGA
Pixel Pitch 0.3075 x 0.3075 mm
Max. Colors 16.2M (24-bit)
Luminance 250 cd/m²
触摸屏
Type 8-wire, Analog Resistive
(P1270-1200-P / P1270-1200-C only)
Resolution Continuous
Light Transparency 80%
Interface USB Interface
电源
Requirement DC 10 ~ 30V
Consumption 2.56A/12V
输入/输出接口
Serial Port 2 x RS-232 ports
USB Port Front: 1 x USB 2.0 port (for panel-mounting type only)
Bottom: 4 x USB 2.0 ports
KB/MS 1 x 6-pin Mini-DIN connector for Keyboard and Mouse
(PS/2 standard via Y-cable)
LAN 1 x RJ45
VGA 1 x DB15 female connector
Audio Mic-in/Line-in/Line-out
Expansion Bus 1 x Mini PCI socket
机构
Mounting Type Panel-mounting or chassis-mounting (Standard VESA)
Tempered Glass 3 mm (P1270-1100-P, P1270-1100-C only)
Construction Steel (w/ aluminum bezel for panel-mounting type)
Dimension
(W x D x H)
Chassis-mounting type:
319 x 65 x 249 mm (12.56" x 2.56" x 9.8")
Panel-mounting type:
326 x 65 x 259 mm (12.83" x 2.56" x 10.2")
环境
Operating Temp. 0 ~ 50°C (32 ~ 122°F)
Storage Temp. -20 ~ 80°C (-4 ~ 176°F)
Operating Humidity 10 ~ 95% RH @40°C (non-condensing)
Vibration 5~500Hz, 1Grms
订货信息
CSP12-CM-1100-P 12.1" panel-mounting panel PC with tempered glass,
Intel Celeron M 1.0GHz CPU, 1GB DDR SDRAM
CSP12-CM-1200-P 12.1" panel-mounting panel PC with resistive touch
screen, Intel Celeron M 1.0GHz CPU, 1GB DDR SDRAM
CSP12-CM-1100-C 12.1" chassis-mounting panel PC with tempered glass,
CSP12-CM-1200-C 12.1" chassis-mounting panel PC with resistive touch
PAC-P065W 65WAC/DC adapter kit
人机界面 CSP12-CM
工业物联网“CONPROSYS™ M2M网关系列”支持楼宇自动化通信协议“BACnet”
 工业用计算机的基础知识( 四 )  (显示器接口)
康泰克最新推出 - 采用新散热技术将工作温度范围扩展了多达40%的 大功率无风扇嵌入式PC“盒式计算机 BX-M2510”
工业用计算机的基础知识( 三)  (扩展插槽)
边缘计算 / 工业用计算机的基础知识(一) (CPU/芯片组)
