产品选型
CONTEC康泰克CST15-AT
CONTEC康泰克CST15-AT
CST15-AT 15" Intel AtomTM N270 Ultra Slim Fanless Touch Panel Computer 人机界面CST15-AT 板载Intel AtomTM N270 1.6GHz CPU 15" 1024 × 768 XGA 彩色TFT LCD 显示 被动散热系统(无风扇) 超薄和紧凑机构设计 S.D.R.(内存备份用于数据恢复) 隔离串口(RS-232/422/485)/CAN-BUS 前面板NEMA4/IP65兼容 PC/104 扩展总线 兼容OPC和SCADA应用软件
产品分类:
品牌:
康泰克
CST15-AT
人机界面CST15-AT
被动散热系统(无风扇)
超薄和紧凑机构设计
S.D.R.(内存备份用于数据恢复)
前面板NEMA4/IP65兼容
PC/104 扩展总线
兼容OPC和SCADA应用软件
系统
CPU Intel Atom™ N270 1.6GHz processor
Memory 1 x 200-pin SO-DIMM Socket support DDR2
400/533MHz SDRAM up to 2GB
512KB FRAM soldered onboard for S.D.R.
Chipset Intel 945GSE + ICH7M
LAN 2 x Realtek RTL8111B 10/100/1000Base-T
Watchdog Timer Programmable as 250ms, 500ms,1 second
存储
HDD/Type 1 x 2.5" drive bay for SATA HDD/SSD
Flash Disk 1 x CompactFlash socket
LCD 显示
Size/Type 15" TFT LCD
Max. Resolution 1024 x 768, XGA
Backlight Life 50,000 hours
Luminance 350 cd/m²
Max. Colors 262,144
触摸屏
Type 8-wire, Analog resistive
Light Transparency Above 80%
Lifespan 10 million touches at single point
输入/输出接口
Serial Port 2 x Isolated RS-232 ports, 2 x Isolated RS-422/485
port (with optical isolation design of 3.75KV)
Parallel Port 1 x LPT
CAN-Bus Port 1 x CAN-Bus shared with RS-422/485 port
USB Port 2 x USB 2.0 (Host)
KB/MS 1 x PS2 Keyboard and Mouse
Expansion Bus 1 x PC/104
电源信息
Connector One ME-050 3-pin DC jack for power adapter
Power Input DC 9 ~ 33V
Power Consumption 45W
机构与环境
Operating Temp. 0 ~ 50°C (32 ~ 122°F)
Storage Temp. -20 ~ 60°C (-4 ~ 140°F)
Operating Humidity 10 ~ 95% RH @40°C (non-condensing)
Ingress Protection Front panel: NEMA4, IP65
Vibration Protection 1Grms (with CF or SSD)
Dimensions (Wx Dx H) 390 x 52.3 x 310 mm (15.35" x 2.06" x 12.2")
Weight (Net) 4.4 kg (9.7 lb)
Enclosure Aluminum (Front Panel), PC + ABS (Bezel)
订货信息
CST15-AT-E
15" Intel Atom™N270 ultra slim fanless touch panel
computer barebone w/o FRAM, isolated COM, CAN-BUS
and memory
CST15-AT CST15-AT-E with FRAM, Isolated COM, CAN-BUS, 1GB
SDRAM
VMB-CST15-AT CST15-AT VES A mount bracket kit
ARM-150 VESA-75/100 desktop LCD monitor ARM
PAC-P065W 65WAC/DC adapter kit
工业物联网“CONPROSYS™ M2M网关系列”支持楼宇自动化通信协议“BACnet”
 工业用计算机的基础知识( 四 )  (显示器接口)
康泰克最新推出 - 采用新散热技术将工作温度范围扩展了多达40%的 大功率无风扇嵌入式PC“盒式计算机 BX-M2510”
工业用计算机的基础知识( 三)  (扩展插槽)
边缘计算 / 工业用计算机的基础知识(一) (CPU/芯片组)
