产品选型
CONTEC康泰克CST06-LX/CST06M-LX
5.7" AMD LX900 超薄无风扇触摸平板电脑 人机界面CST06-LX/CST06M-LX 板载AMD LX900 600MHz 32-bit × 86 CPU Core 5.7" 640 × 480 VGA 彩色TFT LCD 显示 被动散热系统(无风扇) 超薄和紧凑机构设计 S.D.R.(内存备份用于数据恢复) 隔离串口(RS-232/422/485)/CAN-BUS 前面板NEMA4/IP65兼容 PC/104 扩展总线 兼容OPC和SCADA应用软件
产品分类:
品牌:
康泰克
被动散热系统(无风扇)
超薄和紧凑机构设计
S.D.R.(内存备份用于数据恢复)
前面板NEMA4/IP65兼容
PC/104 扩展总线
兼容OPC和SCADA应用软件
系统
CPU AMD LX900 600MHz 32-bit x86 CPU
Memory 512MB DDR SDRAM SO-DIMM installed
512KB FRAM soldered onboard for S.D.R.
Chipset AMD LX900 + CS5536
LAN 1 x Realtek RTL8110SCL 10/100/1000Base-T
WatchdogTimer Programmable as 250ms, 500ms,1 second
存储
Flash Disk 1 x CompactFlash socket
LCD 显示
Size/Type 5.7" TFT LCD
Max.Resolution 640 x 480, VGA
Backlight Life 50,000 hours
Luminance 220 cd/m²
Max. Colors 262,144
触摸屏
Type 4-wire, Analog resistive
Ligh tTransparency Above 75%
Lifespan 10 million touches at single point
输入/输出接口
Serial Port 2 x Isolated RS-232 ports
1 x Isolated RS-422/845 port
(with optical isolation design of 3.75KV)
CAN-Bus Port 1 x CAN-Bus shared with RS-422/485 port (Optional)
USB Port 2 x USB 2.0 (Host)
KB/MS 1 x PS2 Keyboard and Mouse
Expansion Bus 1 x PC/104
电源系统
Connector One ME-050 3-pin DC jack for power adapter
Power Input DC 9 ~ 33V
Power Consumption 20W
机构与环境
Operating Temp. 0 ~ 50°C (32 ~ 122ºF)
Storage Temp. -20 ~ 60°C (-4 ~ 140ºF)
Operating Humidity 10 ~ 95% RH @ 40°C (non-condensing)
Ingress Protection Front panel: NEMA4, IP65
Vibration Protection 1Grms
Dimensions (Wx Dx H) 186 x 47.5 x 140 mm (7.32" x 1.87" x 5.51")
Weight (Net) 0.8 kg (1.8 lb)
Enclosure PC + ABS
增强特点
Sunlight Readable A.L.T.T.(Advanced Low-reflecition Touch Technology)
Solution Solution
订货信息
CST06-LX/CST06M-LX 5.7" AMD LX900 ultra slim fanless touch panel computer
with 512MB SDRAM, without CAN-Bus
CST06-LX-S/CST06M-LX-S CST06-LX/CST06M-LX with sunlight readable solution
CST06-LX-E/CST06M-LX-E CST06-LX/CST06M-LX without FRAM, Isolation COM, CAN-Bus
CST06-LX-C/CST06M-LX-C CST06-LX-E/CST06M-LX-E with CAN-Bus
PAC-P065W 65WAC/DC adapter kit
工业物联网“CONPROSYS™ M2M网关系列”支持楼宇自动化通信协议“BACnet”
 工业用计算机的基础知识( 四 )  (显示器接口)
康泰克最新推出 - 采用新散热技术将工作温度范围扩展了多达40%的 大功率无风扇嵌入式PC“盒式计算机 BX-M2510”
工业用计算机的基础知识( 三)  (扩展插槽)
边缘计算 / 工业用计算机的基础知识(一) (CPU/芯片组)
