ICA2000 系列
19" 4U Intel Core2 processor inside
整机ICA2000系列
Intel Core2 E2200 2.2GHz
DDR2 533/667/800 up to 2GB
AC97 Audio Daughterboard
底板包含PCI slot × 4,ISA slot × 10
主板
CPU Intel Core2 E2200 2.2GHz
内存DDR2 533/667/800 2GBx1
存储1 x 3.5" HDD 320G (SATA )
芯片组Intel 945G+ICH7
显示芯片Integrated with Intel Graphics Media Accelerator (945G)
CRT s& DVI
IDE 1 x 40-pin IDE interface, support UDMA33 IDE device
ATA 4 x Serial ATA SATA II ports with 300MB/s HDD transferrate
ATA-100 x 1 channel,compact card socket x 1
底板PCI x 4,ISA x 10
系统
网络Intel 82537 1000 base-T Gigabit LAN
串口2 x RS232
USB 接口6 x USB 2.0 ports(D-type connector & pin Header x4 ports)
键盘/鼠标1 x 6-pin Mini-DIN for Keyboard and Mouse
I/OParallel x1,Spport SPP/EPP/ECP,FDD header
40 pin header SDVD Daughterboard connector
VGA 1 x DB15 female connector
音频AC97 2.3 codec,support MIC-in/Line-In/Line-Out
可选I/O 接口Fintek F81216,supports COM3,COM4(RS232
数字量I/O8-bit DIO
CD/DVD设备DVD-ROM 16X
指示灯LED for power, HDD, LAN
机构与环境
工作温度w/ Hard Drive: -20 ~ 55°C (-4 ~ 131°F), ambient w/ air flow
w/ CompactFlash: -20 ~ 55°C(-4 ~ 131°F), ambient w/ air flow
工作湿度10 ~ 95% @ 40°C (non-condensing)
抗振性17 to 500Hz, 1G PTP
抗冲击性(仅带CF) Operating 10G, 11ms; Non-operating 40G, 11ms
电源
输入电压90 ~ 240VAC,47~ 63Hz
电压输出8.0A for 115VAC,4.0A for 230VAC
输入电流65A max for 115VAC,125A max for 230VAC
电源功耗400W max, ATX 2.03
认证CE, FCC,CCC
常规规格
CE, FCC,CCC
外壳Steel
OS 支持Microsoft Windows 2000/XP/XPe/CE.Net, Linux
看门狗255-level reset
尺寸(WxDxH)473 x 500 x 177
重量20KG
安装19" 4U
