佳乐 RMIA4524VDC,RMIA21024VDC,RN1F48I50 中间继电器
2013/8/22 9:57:25
Carlo Gavazzi瑞士佳乐RMIA4524VDC,RMIA21024VDC,RN1F48I50中间继电器
产品分类:低压电器 控制电器 继电器
品牌:佳乐
外型尺寸:56*35.5*35.5
触点对数:2对,3对,4对
额定电流:25A,50A,90A,110A
触点电流:10A
电气寿命:大于100000次
开关功率:2500VA阻性负载
电压范围:6-12-24-48-60VDC
电压范围:6-12-24-49-115-120-230VAC
绝缘等级:EN61810-5
功率:1.5W
标准配置:测试/信号灯/LED
认证/标准:CE-UL-CSA
RMIA210110DC: RMI relay 2 contact CO DC coil
RMIA210120AC: RMI relay 2 contact CO AC coil
RMIA21012AC: RMI relay 2 contact CO AC coil
RMIA21012DC: RMI relay 2 contact CO DC coil
RMIA210220AC: RMI relay 2 contact CO AC coil
RMIA210240AC: RMI relay 2 contact CO AC coil
RMIA21024AC: RMI relay 2 contact CO AC coil
RMIA21024DC: RMI relay 2 contact CO DC coil
RMIA21048AC: RMI relay 2 contact CO AC coil
RMIA21048DC: RMI relay 2 contact CO DC coil
RMIA21060DC: RMI relay 2 contact CO DC coil
RMIA45110VDC: RMI relay 4 contact CO DC coil
RMIA45120VAC: RMI relay 4 contact CO AC coil
RMIA4512VAC; RMI relay 4 contact CO AC coil
RMIA4512VDC; RMI relay 4 contact CO DC coil
RMIA45220VAC; RMI relay 4 contact CO AC coil
RMIA45240VAC; RMI relay 4 contact CO AC coil
RMIA4524VAC: RMI relay 4 contact CO AC coil
RMIA4524VDC; RMI relay 4 contact CO DC coil
RMIA4548VAC: RMI relay 4 contact CO AC coil
RMIA4548VDC: RMI relay 4 contact CO DC coil
RMIA4560VDC; RMI relay 4 contact CO DC coil
RMIB210110DC: RMI relay 2 contact CO DC coil, PCB term.
RMIB210120AC: RMI relay 2 contact CO AC coil, PCB term.
RMIB21012AC: RMI relay 2 contact CO AC coil, PCB term.
RMIB21012DC: RMI relay 2 contact CO DC coil, PCB term.
RMIB210220AC: RMI relay 2 contact CO AC coil, PCB term.
RMIB210240AC: RMI relay 2 contact CO AC coil, PCB term.
RMIB21024AC: RMI relay 2 contact CO AC coil, PCB term.
RMIB21024DC: RMI relay 2 contact CO DC coil, PCB term.
RMIB21048AC: RMI relay 2 contact CO AC coil, PCB term.
RMIB21048DC: RMI relay 2 contact CO DC coil, PCB term.
RMIB21060DC: RMI relay 2 contact CO DC coil, PCB term.
RMIB45110VDC: RMI relay 4 contact CO DC coil, PCB term.
RMIB45120VAC: RMI relay 4 contact CO AC coil, PCB term.
RMIB4512VAC: RMI relay 4 contact CO AC coil, PCB term.
RMIB4512VDC: RMI relay 4 contact CO DC coil, PCB term.
RMIB45220VAC: RMI relay 4 contact CO AC coil, PCB term.
RMIB45240VAC; RMI relay 4 contact CO AC coil, PCB term.
RMIB4524VAC; RMI relay 4 contact CO AC coil, PCB term.
RMIB4524VDC: RMI relay 4 contact CO DC coil, PCB term.
RMIB4548VAC: RMI relay 4 contact CO AC coil, PCB term.
RMIB4548VDC: RMI relay 4 contact CO DC coil, PCB term.
RMIB4560VDC: RMI relay 4 contact CO DC coil, PCB term.
外型尺寸:56*35.5*35.5
触点对数:2对,3对,4对
触点电流:10A
电气寿命:大于100000次
开关功率:2500VA阻性负载
绝缘等级:EN61810-5
功率:1.5W
标准配置:测试/信号灯/LED
认证/标准:CE-UL-CSA
美国霍尼韦尔Honeywell限位开关BZ-2RW822-A2
图尔克TURCK电感式传感器Bi10-M30-AZ3X/S90 6m
基恩士KEYENCE光纤放大器FS-N13N
德国马赫MACHER电感式接近开关FBB-12D04N1-DS1250
美国伊顿EATON断路器FAZ-C25/1-NA
