产品选型
Ubiqconn攸泰科技 RPP-150 专业型平板电脑
2011/3/16 0:00:00
* 15”” TFT LCD 强固型铝合金外壳 * 无需风扇及散热孔设计 * IP65 防尘防水等级 (5面) * 宽温操作环境设计 * 硬盘防震以及易拆装设计 * 防眩光面板Sunlight Readable (选配) * 脚架/机箱/VESA挂架 (选配)
产品分类:
品牌:
大众工控
    Ubiqconn攸泰科技性能平板电脑, 超越您对平板电脑的期待, 展示给您一个真正清晰的画面。
        RPP-150是一款60mm厚度极端超薄的平板电脑,可在恶劣环境稳定工作的工业级触控平板计算机。主要应用于工业控制领域、KIOSKS,自动化设备控制、楼宇自动化、工厂自动化、智能家居自动化、医疗查询、环境检测等领域。
System CPU Intel Celeron M 1G/512K
Chipset Intel 910GMLE + ICH6M
Memory 1 x 200pin DDR2 400/533MHz SO-DIMM max. up to 2GB
Ethernet Intel 82562EZ 10/100 LAN
Dimensions 376 (W) x 292(H) x 60.8 (D) mm
Weight 6.5 kg
OS Support Windows XP Embedded, Linux (Fedora 2.6), WinCE 6.0
Industrial Grade Display Display Type 15“ TFT LCD
Max Resolution 1024 x 768 pixels
Colors 16.7M colors
Luminance 300 cd/m2
Contrast Ratio 800:1
Viewing Angel(CR=10) 70° (left), 70° (right), 65° (up), 75° (down)
Touch Screen Touch Screen Type 5-wire Analog resistive
I/O Interface Serial 1 x RS-232, 1 x RS-232/422/485 (COM2)
USB 3 x USB 2.0
Audio 1 x AC97 codec with 2W amplifier
VGA 1 x D-SUB15 VGA connector supporting up to 1600 x 1200
Ethernet 1 x RJ45 connector for 10/100 base T Ethernet
E-SATA 1 x E-SATA
CF Card Socket 1 x CF type I/II (Internal)
Mini PCIe Socket 1 x Full size (Internal)
Power DC Input Voltage Wide range 12-24V DC/DC input
AC/DC Adapter Input:110V ~240VAC Output:19V@3.42A 65W
Environment Operating Temperature 0°C~45°C w/ normal type , -10°C~60°C w/ wide temperature SSD & LCD
Storage Temperature -20°C~60°C w/ normal type , -30°C~80°C w/ wide temperature SSD & LCD
Humidity 5% ~ 95% RH, non-condensing
Certifications CE, FCC, VCCI
Protection Class IP65 five sides
MIL-STD-810G Shock Method 516.6 Function shock:40G’s@11ms / Crash Shock:75G’s@8-13ms (Non-operating)
Vibration Resistance MIL-STD-810G, Method 514.6 (Operating)
Hight Temperature MIL-STD-810G, Method 501.5, Operating:65°C / Storage:80°C
Low Temperature MIL-STD-810G, Method 502.5, Operating:-15°C / Storage:-30°C
Ubiqconn攸泰科技 EMB-861AB主板的使用手册
军工规电脑成长稳定 大众推新款强固平板
FIC参展全球第二大ICT专业采购展览会Computex
E-menu电子菜单闪耀2011上海国际酒店用品展
FIC大众工控 APP-126 专业型平板电脑
