华耀电子150W单路输出平板开关电源
2011/9/28 9:11:03
华耀电子150W单路输出平板开关电源Approvals: CE,TUVmark,CB, UL pending 产品特性: ● AC输入,手动开关转换 ● 通电指示灯 ● 过载/过压/短路保护 ● 小体积,高效率,高可靠性 ● 100%满载老化测试 ● 2年质保
产品分类:工业电源 开关电源
品牌:产品介绍
产品特性: | |||
● AC输入,手动开关转换 | Product features: | ||
● 通电指示灯 | ● AC input selectable by switch | ||
● 过载/过压/短路保护 | ● Power on indication | ||
● 小体积,高效率,高可靠性 | ● Protections:Overload /Over voltage /Short circuit | ||
● 100%满载老化测试 | ● Compact, high reliability, high efficiency | ||
● 2年质保 | ● 100% full load burn-in test | ||
● 2 years warranty | |||
技术参数: | Specifications: | ||
输入电压 | 88~132VAC/176~264 VAC | AC input voltage | 88-132VAC/176-264 VAC |
255~370VCD | 255~370VCD | ||
输入频率 | 47~63Hz | Input frequency | 47~63Hz |
冲击电流 | 35A@230VAC, 满载冷态 | Inrush current | 35A @230VAC, full load cold start |
维持时间 | >20ms@230 VAC 满载 | Hold up time | >20ms@230 VAC full load |
过载保护 | 110%- 150% | Overload protection | 110%- 150% |
过压保护 | 110%-145% | Over voltage protection | 110%-145% |
运行温度 | -20~ 70℃,实据降额曲线 | Operating temperature | -20 ~ 70℃ |
安全标准 | UL60950 | refer to output derating curve | |
EMC标准 | EN55022 class B | Safety standard | UL60950-1 |
MTBF | 200kHrs at 25℃ | EMC standard | EN55022 class B |
绝缘标准 | I/P-O/P: 1.5KVAC,1min | MTBF | 200kHrs at 25℃ |
I/P-FG:1.5KVAC,1min | Withstand voltage | I/P-O/P: 1.5KVAC,1min | |
O/P-FG:0.5KVAC,1min | I/P-FG:1.5KVAC,1min | ||
重 量 | 0.7Kg/pcs | O/P-FG:0.5KVAC,1min | |
Weight | 0.7Kg/pcs |
P/N | Output | Tol. | R&N | Effi. | Load Regulation | DC adjustment range |
产品型号 | 输出 | 容差 | 纹波&噪声 | 效率 | 负载调整率 | DC可调范围 |
EPR-150-5 | 5V,22A | ±3% | 80mV | 77% | ±2% | 4.75V ~5.25V |
EPR-150-12 | 12V,12.5A | ±3% | 120mV | 83% | ±2% | 10.8 V ~13.2V |
EPR-150-15 | 15V,10A | ±3% | 120mV | 83% | ±2% | 13.5 V ~16.5V |
EPR-150-24 | 24V,6.5A | ±3% | 120mV | 86% | ±2% | 21.6 V~26.4V |
EPR-150-36 | 36V,4.1A | ±3% | 200mV | 86% | ±2% | 32.4 V~39.6V |
EPR-150-48 | 48V,3.3A | ±3% | 200mV | 87% | ±2% | 43.2 V ~52.8V |
华耀将参加慕尼黑上海电子展(electronica China 2018)
华耀电源参展第十届中国国际国防电子展览会
华耀电子即将参加2016年中国国际电梯展览会
华耀电子与您相约2016福州体博会
华耀电子即将参加2016年慕尼黑上海电子展
