华耀电子 35W 单路输出平板开关电源
2011/11/7 8:55:40
产品特性: ● 全范围AC输入 ● 通电指示灯 ● 过载/过压/短路保护 ● 小体积,高效率,高可靠性 ● 可配合导轨安装 ● 100%满载老化测试 ● 1~3年质保 ● 尺寸:105mm×81mm×36.5mm
产品分类:工业电源 开关电源
品牌:产品介绍
产品特性: | Product features: | ||
● 全范围AC输入 | ● Universal AC input/ full range | ||
● 通电指示灯 | ● Power on indication | ||
● 过载/过压/短路保护 | ● Protections:Overload /Over voltage /Short circuit | ||
● 小体积,高效率,高可靠性 | ● Compact, high reliability, high efficiency | ||
● 100%满载老化测试 | ● 100% full load burn-in test | ||
● 2年质保 | ● 2 years warranty | ||
技术参数: | Specifications: | ||
输入电压 | 88~264VAC | input voltage | 88~264VAC |
常规100-240VAC | Nominal 100-240VAC | ||
输入频率 | 47~63Hz | Input frequency | 47~63Hz |
冲击电流 | 30A@230VAC, 满载冷态 | Inrush current | 30A @230VAC full load cold start |
维持时间 | >20ms@230 VAC 满载 | Hold up time | >20 ms@230 VAC full load |
过载保护 | 110%- 150% | Overload protection | 110%- 150% |
过压保护 | 110%-145% | Over voltage protection | 110%-145% |
运行温度 | -20 ~ 70℃,实据降额曲线 | Operating temperature | -20 ~ 70℃ |
安全标准 | UL60950 | Safety standard | refer to output derating curve |
EMC标准 | EN55022 class B | EMC standard | UL60950 |
MTBF | 200kHrs at 25℃ | EN55022 class B | |
绝缘标准 | I/P-O/P: 1.5KVAC,1min | MTBF | 200kHrs at 25℃ |
I/P-FG:1.5KVAC,1min | Withstand voltage | I/P-O/P: 1.5KVAC,1min | |
O/P-FG:0.5KVAC,1min | I/P-FG:1.5KVAC,1min | ||
重 量 | 0.2Kg/pcs | Weight | O/P-FG:0.5KVAC,1min |
0.2Kg/pcs |
P/N | Output | Tol. | R&N | Effi. | Load Regulation | D, , C adjustment range |
产品型号 | 输出 | 容差 | 纹波&噪声 | 效率 | 负载调整率 | DC可调范围 |
EPR-35-5 | 5V,5A | ±3% | 80mV | 76% | ±2% | 4.75~5.25V |
EPR-35-12 | 12V,3A | ±3% | 120mV | 81% | ±2% | 10.8~13.2V |
EPR-35-15 | 15V,2.3A | ±3% | 120mV | 81% | ±2% | 13.5~16.5V |
EPR-35-24 | 24V,1.5A | ±3% | 120mV | 83% | ±2% | 21.6~26.4V |
EPR-35-36 | 36V,0.9A | ±3% | 200mV | 83% | ±2% | 32.4~39.6V |
EPR-35-48 | 48V,0.8A | ±3% | 200mV | 84% | ±2% | 43.2~52.8V |
华耀将参加慕尼黑上海电子展(electronica China 2018)
华耀电源参展第十届中国国际国防电子展览会
华耀电子即将参加2016年中国国际电梯展览会
华耀电子与您相约2016福州体博会
华耀电子即将参加2016年慕尼黑上海电子展
