华耀电子ESF-200W单路输出PFC开关电源
2011/7/12 22:30:22
● 全范围AC输入● PF >0.98@115VAC,>0.93@230VAC● 通电指示灯● 内置风扇冷却● 过载/过压/短路/过温保护 ● 100%满载老化测试● 1年质保
产品分类:工业电源 开关电源
品牌:产品介绍
产品特性: | Product features: | ||
● 全范围AC输入 | ● Universal AC input/ full range | ||
● PF >0.98@115VAC,>0.93@230VAC | ● PF >0.98@115VAC,>0.93@230VAC | ||
● 通电指示灯 | ● Power on indication | ||
● 内置风扇冷却 | ● Fan cooling | ||
● 过载/过压/短路/过温保护 | ● Protection: Short circuit / Over voltage / Overload/ Over temperature | ||
● 100%满载老化测试 | ● 100% full load burn-in test | ||
● 1年质保 | ● 1 year warranty | ||
技术参数: | Specifications: | ||
输入电压 | 90VAC~264 VAC | input voltage | 90VAC~264 VAC |
输入频率 | 47~63Hz | Input frequency | 47~63Hz |
冲击电流 | 70A@ 230VAC满载冷态 | Inrush current | 70A@220VAC full load cold start |
35A@ 230VAC满载冷态 | 35A@ 230VAC full load cold start | ||
维持时间 | 20 ms@ 80%负载,120 VAC | Hold up time | 20 ms@ 80%load,120 VAC |
过载保护 | 105%-150% | Overload protection | 105%-150% |
过压保护 | 110%-135% | Overload voltage | 110%-135% |
运行温度 | 0~ 50℃ | Operating temperature | 0 ~50℃ |
安全标准 | UL60950,CSA 22.2 No | Safety standards | UL60950,CSA 22.2 No |
EN60950,CE Mark | EN60950,CE Mark | ||
EMC 标准 | EN55022 class B | EMC standard | EN55022 class B |
EN61000 -3-2,3 | EN61000 -3-2,3 | ||
EN61000 -4-2,3,4,5,6,8,11 | EN61000 -4-2,3,4,5,6,8,11 | ||
MTBF | 100kHrs at 25℃ | MTBF | 100kHrs at 25℃ |
绝缘标准 | I/P-O/P: 3KVAC,1min | Withstand voltage | I/P-O/P: 3KVAC,1min |
I/P-FG:1.5KVAC,1min | I/P-FG:1.5KVAC,1min | ||
连接件 | 7P/9.5mm端子排 | Connection | 7P/9.5mm pitch terminal block with cover |
重 量 | 0.85 Kg/pcs | Weight | 0.85Kg/pcs |
P/N | DC Output | Tol. | R&N | Effi. | Load Regulation | Line Regulation |
型号 | 输出 | 容差 | 纹波&噪声 | 效率 | 负载调整率 | 线性调整率 |
ESF-200-5 | 5V,0~40A | ±3% | 100mV | 70% | ±2% | ±1% |
ESF-200-12 | 12V,0~16.7A | ±3% | 100mV | 78% | ±2% | ±1% |
ESF-200-24 | 24V,0~8.4A | ±3% | 150mv | 83% | ±2% | ±1% |
ESF-200-48 | 48V,0~4.2A | ±3% | 250mv | 84% | ±2% | ±1% |
华耀将参加慕尼黑上海电子展(electronica China 2018)
华耀电源参展第十届中国国际国防电子展览会
华耀电子即将参加2016年中国国际电梯展览会
华耀电子与您相约2016福州体博会
华耀电子即将参加2016年慕尼黑上海电子展
