华耀电子EDA 240W单路输出导轨开关电源
2011/7/12 22:17:08
Approvals: CE,UL pending 产品特性: ● 全范围AC输入 ● PF >0.99@ 115VAC, >0.96@ 230VAC ● 高效率,高可靠性 ● 通电指示灯 ● 自然风冷 ● 过载/过压/过温/短路保护 ● 100%满载老化测试 ● 3年质保
产品分类:工业电源 开关电源
品牌:产品介绍
产品特性: | Product features: | ||
● 全范围AC输入 | ● Universal AC input/ full range | ||
● PF >0.99@ 115VAC, >0.96@ 230VAC | ● PF >0.99@ 115VAC, >0.96@ 230VAC | ||
● 高效率,高可靠性 | ● High efficiency,high reliability | ||
● 通电指示灯 | ● Power on indication | ||
● 自然风冷 | ● Air cooling | ||
● 过载/过压/过温/短路保护 | ● Protections:Overload /Over voltage | ||
● 100%满载老化测试 | Over temperature/Short Circuit | ||
● 3年质保 | ● 100% full load burn-in test | ||
● 3 years warranty | |||
技术参数: | Specifications: | ||
AC输入电压 | 常规 100~240VAC | AC input voltage | Normal 100~240VAC |
运行 90~264VAC | Operating 90~264VAC | ||
冲击电流 | 40A@230VAC | Inrush current | 40A@230VAC |
20A@230VAC 满载,冷态 | 20A@230VAC full load,,cold start | ||
过载保护 | 105%- 150% | Overload protection | 105%- 150% ,auto-recovery, |
恒流限制,自动恢复 | constant current limiting | ||
过压保护 | 120%-140%额定输出电压 | 120%-140 % rated output voltage | |
运行温度 | -25 ~70℃(实据降额曲线) | Over voltage protection | -25~70℃(refer to output derating curve) |
安全标准 | EN60950 UL508 | Operating temperature | EN60950 UL508 |
EMC标准 | EN55022 class B | EN55022 class B | |
EN61000-3-2,3 | Safety standards | EN61000-3-2,3 | |
EN61000-6-2 | EMC standards | EN61000-6-2 | |
MTBF | 200kHrs at 25°C | 200kHrs at 25°C | |
绝缘标准 | I/P-O/P:3KV.1min | MTBF | I/P-O/P:3KV.1min |
I/P-FG:1.5KV.1min | Withstand voltage | I/P-FG:1.5KV.1min | |
O/P-FG:0.5KV.1min | O/P-FG:0.5KV.1min | ||
重量 | 0.81kg/pcs | 0.81kg/pcs | |
Weight |
P/N | Output | Tol. | R&N | Effi. | DC adjustment range |
产品型号 | 输出 | 容差 | 纹波&噪声 | 效率 | DC可调范围 |
EDA-240-12 | 12V,0~16A | ±2% | 100 mV | 89% | 12~14V |
EDA-240-24 | 24V,0~10A | ±2%&, lt;, o:p>, | 100mV | 91% | 24~28V |
EDA-240-48 | 48V,0~5A | ±2% | 150mV | 92% | 48~53V |
华耀将参加慕尼黑上海电子展(electronica China 2018)
华耀电源参展第十届中国国际国防电子展览会
华耀电子即将参加2016年中国国际电梯展览会
华耀电子与您相约2016福州体博会
华耀电子即将参加2016年慕尼黑上海电子展
