steute ES 13 安全行程开关
安全行程开关
产品分类:离散传感器 功能安全 物联网 行程开关 感知层 设备安全 位置检测
品牌:世德
Features/Options
· Thermoplastic enclosure
· Double insulated
· Slow action, change-over contact or 2 NC/1 NO contact with double break
· Slow action available with contact overlapping
· Max. 3 contacts
· Version with 3 contacts has cable on left-hand side
· Suitable for in-line mounting
· With pre-wired cable
· Gold-plated contacts available on request
· Pneumatic version available on request
· Ex version available
Technical data
Standards |
IEC/EN 60947-5-1 |
Enclosure |
glass-fibre reinforced, shock-proof thermoplastic, self-extinguishing UL 94-V0 |
Degree of protection |
IP 67 to IEC/EN 60529 |
Contact material |
silver |
Switching system |
slow action, positive break |
Switching elements |
change-over contact or 2 NC/1 NO contact with double break with galvanically separated contact bridges |
Connection |
cable: 2 contacts: H05VV-F, |
Cable section |
2 contacts: 4 x 0.75 mm²; |
Uimp |
4 kV |
Ui |
250 V |
Ithe |
6 A |
Ie/Ue |
6 A/250 VAC; 0.25 A/230 VDC |
Utilisation category |
AC-15, DC-13 |
Max. fuse rating |
6 A gL/gG D-fuse |
Ambient temperature |
–20 °C … +75 °C |
Mechanical life |
> 1 million operations |
Switching frequency |
1800/h |
Repeat accuracy of switching points |
± 0.1 mm |
Impact resistance/ |
2 contacts: max. 2 x 4 mm; |
steute参加上海2012工业自动化展
steute STM 295 磁锁开关
steute ST 14 安全门锁开关
steute ES 95 AZ 安全门锁开关
steute ST 61 安全门锁开关
