产品选型
steute Safety relay module SRM 21 RT2 安全继电器
安全继电器
产品分类:
功能安全 设备安全 安全检测与防护 安全继电器
品牌:
世德
 Features/Options
·         Enclosure width: 22.5 mm
·         2 NC or 1 NC/1 NO contact can be connected
·         Feedback circuit
·         2 enabling paths
·         1 transistor output
·         Manual or automatic reset
·         LED indicator for switching condition
·         Crossed wire monitoring
Technical data
Standards
IEC/EN 60204-1,
IEC/EN 60947-5-1,
IEC/EN 60947-5-3/PDF-M, EN 954-1, BG-GS-ET 20
GS-ET 14
Enclosure
black polycarbonate; polyamide terminal clamps, top hat section rail mounting to EN 50022
Connection
screw terminals with + and - screws
Cable section
1x 2.5 mm²/2x 1.5 mm² strand including conductor ferrules,
1x 4 mm²/
2x 2.5 mm² massive
Degree of protection
Enclosure IP 40, Terminal block
IP 20 to IEC/EN 60529,
shock protection to VBG 4
Safety-relevant data:
EN 954-1
Category 4
EN ISO 13849-1
PL e
MTTFd
39.5 years
DIN EN 62061
SIL CL 3
PFHD
≥ 3 x 10-8
TM
max. 20 years
Ie/Ue power supply
0.1 A/24 VDC ±15 %
Inputs
1 NC/1 NO contact or 2 NC contacts
1 feedback input, 1 reset input
Outputs
enabling paths: positive-guided contacts, 1 transistor output as signalling contact
Utilisation category
AC-15; DC-13
Ie/Ue enabling paths
3 A/230 VAC; 2 A/24 VDC
Max. output current transistor
output Ia
20 mA
Max. fuse rating Ue
2 A gL/gG D-fuse
Max. fuse rating enabling paths
6 A gL/gG D-fuse
Classification
stop category 0
Dropout delay
< 20 ms
Risk time
< 200 ms
Mechanical life
> 50 million operations
LED indications
4: operation, authorisation, inputs A and B
Degree of pollution
3 to DIN VDE 0110
Overvoltage category
III
Ambient temperature
0 °C … +55 °C
steute参加上海2012工业自动化展
steute STM 295 磁锁开关
steute ST 14 安全门锁开关
steute ES 95 AZ 安全门锁开关
steute ST 61 安全门锁开关
