CARLO GAVAZZI瑞士佳乐 SPD05181 导轨式开关电源
CARLO GAVZZI瑞士佳乐 SPD05181单相开关电源,输出规格:24VDC,2.5A,±5%,48VDC,1.25A
产品分类:工业电源 开关电源
品牌:佳乐
外型尺寸:90*40.5*115
输入规格:通过开关:93-132VAC,186-264VAC,210-370VDC
频率范围:47-63HZ
工作温度:-10度至71度
认证:UL,CUL,TUV,CE
安装:DIN导轨,紧固型端子和可分离紧固端子(B)
特殊参数:输出电源可调节,内部干扰滤波,短路保护,过载保护(110-135%),输出电源OK,直流电压信号(仅24VDC型)
LED指示电源来电:YES
LED指示DC电压过低,YES:24V 带继电器输出(仅24VDC型
SPD05051, Switching Power Supply 5W, DIN Rail
SPD05051B, Switching Power Supply 5W, DIN Rail, Spring terminals
SPD05101, Switching Power Supply 10W, DIN Rail
SPD05101B, Switching Power Supply 10W, DIN Rail, Spring terminals
SPD05181, Switching Power Supply 18W, DIN Rail
SPD05181B, Switching Power Supply 18W, DIN Rail, Spring terminals
SPD05301, Switching Power Supply 30W, DIN Rail,
SPD05301B, Switching Power Supply 30W, DIN Rail, Spring terminals
SPD05601, Switching Power Supply 60W, DIN Rail
SPD05601B, Switching Power Supply 60W, DIN Rail, Spring terminals
美国霍尼韦尔Honeywell限位开关BZ-2RW822-A2
图尔克TURCK电感式传感器Bi10-M30-AZ3X/S90 6m
基恩士KEYENCE光纤放大器FS-N13N
德国马赫MACHER电感式接近开关FBB-12D04N1-DS1250
美国伊顿EATON断路器FAZ-C25/1-NA
