集智达 NSP-3111 机架式网络安全平台
• 1U 机架式网络安全平台 • Intel® Core™ 2 Duo/Pentium® Dual Core/Celeron® , 800/1066/1333 MHz FSB 和 1MB/2MB Cache • DIMM x 2, Support DDR2 800/667 with Non-ECC内存,最大4GB • Intel® G41 芯片组 • 支持1个局域网模块, 1 PCI 扩展插槽 • 内嵌 2.5" x 2 HDD Bay
产品分类:互联网安全
品牌:集智达智能
处理器 | Support Intel® Core™ 2 Duo/Pentium® Dual Core/Celeron® Processors in 775-pin, LGA775 package Support 800/1066/1333 MHz FSB Intel® G41 and ICH7R Chipset |
内存 | 2 x 240-pin DDR2 800/667 DIMM Sockets, up to 4GB Non-ECC DDR2 SDRAM |
网络特点 | Onboard 6G LAN and One LAN Modular Lan Chipset: Intel® 82574L Support 10/100/1000 link speed LAN BYPASS: by model *Please see module list information in Datasheet (PDF) |
扩展 | Support 1 x PCI Slot Support 1 x Mini-PCI Slot |
I/O 接口-前面板 | HDD access/Power/GPIO status LEDs 2 x USB 2.0 ports 1 x RJ45 type Console port 1 x software button 4~6 Copper LAN ports 1 x LAN Module bay |
I/O 接口-后面板 | 1 x Expansion slot 1 x power switch |
设置 | 1 x on-board CompactFlash socket 1 x Internal 2.5" HDD driver bay 1 x Internal 44 pin IDE interface |
电源输入 | Support 200W ATX Power Supply |
尺寸规格 | Chassis Dimension: 426mm x 450mm x 44mm Carton Dimension: 560mm x 640mm x 200mm |
认证 | CE approval FCC Class A UL |
集智达网络安全计算机——网闸篇
集智达PCIe扩展网卡4个千兆电口国产网卡芯片标准竖插扩展网卡
集智达重磅推出基于国产化X86架构处理器的高性能网络安全计算机
集智达CTC设备为国铁建设助力
集智达推出基于国产化平台的边缘服务器
