集智达智能 NISE 3142 无风扇工业计算机
2012/1/9 18:51:38
支持 Intel® Core™ 2 Duo/ Celeron® 处理器 Intel® GM45 芯片组 双 Intel® 82574L Gigabit Ethernet 接口 双独立DVI显示 5 x RS232 和 1 x RS232/ 422/ 485(数据流量控制) 1个外接的可锁CFast槽 板载直流电源设计,支持16V ~ 30V 直流电源输入 支持ATX 电源模式和PXE/ WOL/ 网络唤醒功能
产品分类:工控机 嵌入式系统 物联网 应用层 工控机整机 单板电脑 嵌入式应用
品牌:集智达智能
芯片组
Intel® GM45 Graphics and Memory Controller Hub
Featureing the Mobile Intel Graphics Media Accelerator 4500MHD
Intel® 82801IBM I/O Controller Hub
内存
2x 240-pin DIMM, up to 4GB DDR3 800/1066 MHz SDRAM, un-buffered and non-ECC
前面板I/O
ATX power on/off switch
HDD Access/Power status LEDs
2 x USB2.0 ports
后面板I/O
2-pin Remote Power on/off switch
16 ~ 30V DC input
1 x PS/2 for Keyboard/Mouse
1 x DB25 Parallel Port (Optional GPIO or LVDS interface)
1 x DB44 Serial Port for 4x RS232 (COM2: RS232/422/485 with Auto Flow Control)
2 x Gbe LAN ports
4 x USB2.0 ports
1 x DB15 VGA port
1 x DVI-I Port (DVI-D + VGA)
1 x Speaker-out and Line-in
扩展
Two PCI expansion (NISE3140P2 only)
One PCI and one PCIe x1 expansion (NISE3140P2E only)
Max. Support Add-on Card Length: 1x 169mm and 1x 240mm
配置
1 x 2.5" SATA HDD drive bay
One external locked CF card socket
Optional power adapter
电源
ATX power mode
On-board DC to DC power support from 16V to 30VDC
工作环境
Operating temperature: Ambient with air flow: -5°C ~ - 55°C (According to IEC60068-2-1, IEC60068-2-2, IEC60068-2-14)
Storage temperature: -20°C ~ 80°C
Relative humidity: 10% to 93% (Non-Condensing)
尺寸
195mm (W) x 268 mm (D) x 101mm (H) (7.6" x 10.5" x 4.2")
集智达网络安全计算机——网闸篇
集智达PCIe扩展网卡4个千兆电口国产网卡芯片标准竖插扩展网卡
集智达重磅推出基于国产化X86架构处理器的高性能网络安全计算机
集智达CTC设备为国铁建设助力
集智达推出基于国产化平台的边缘服务器
