集智达 Nise 90无风扇工控机
2012/2/21 17:17:15
板载Intel® Atom™ E620 0.6GHz 处理器 板载DDR2 512MB 内存芯片 2x Intel GbE LANs 3x USB2.0 / 1x VGA / 3x 串口 / 1x CAN bus 8CH GPI 和 8CH GPO 支持 1x 2.5” 硬盘支架 支持 12V 或 24V 电源输入
产品分类:工控机 工控机整机
品牌:集智达智能
主板 | On-board Intel® Atom? E620 0.6GHz processor, 512K Cache On-board Chipset: Intel® EG20T |
内存 | On-board DDR2 512MB memory chip, unbuffered and non-ECC support |
存储设置 | 1x 2.5" SATA HDD drive bay for optional SSD or HDD Support optional SATA DOM, Horizontal type only |
I/O 接口-前面板 | 3x USB ports 2x RJ45 GbE LAN ports, Intel 82574L controller on board support LAN teaming function 3x DB9 Serial ports COM1: Support RS232/422/485 (Selected on BIOS menu) COM2: Support RS232 only COM3: Support RS232 only 1x DB9 CAN Bus . Support CAN 2.0b protocol . Support both 11-bit and 26-bit identifiers . Support bit rates up to 1Mbps . Clock frequency of 40MHz |
I/O 接口=底板 | 1x DB15 VGA port 1x DB15 male connector for 8CH General Purpose Input 1x DB15 male connector for 8CH General Purpose Output 3-pin DC input either for 12V DC input or 24V DC input 1x Power on/off switch |
规格尺寸 | 59mm (W) x 140mm (D) x167mm (H) |
构造 | Aluminum chassis with fanless design |
环境 | Operating temperature: Ambient with air flow: -5 ~ 55°C (According to IEC60068-2-1, IEC60068-2-2, IEC60068-2-14) Storage temperature: -20 ~ 80°C Relative humidity: 10% ~ 93% (non-condensing) Shock protection: 20G, half sine, 11ms, IEC60068-2-27 Vibration protection Random: 0.5Grms @5~500 Hz according to IEC68-2-64 Sinusoidal: 0.5Grms @5~500 Hz according to IEC68-2-6 |
认证 | CE FCC Class A |
集智达网络安全计算机——网闸篇
集智达PCIe扩展网卡4个千兆电口国产网卡芯片标准竖插扩展网卡
集智达重磅推出基于国产化X86架构处理器的高性能网络安全计算机
集智达CTC设备为国铁建设助力
集智达推出基于国产化平台的边缘服务器
