ROKO SN04-N,SN04-P接近开关
2012/3/29 14:06:55
ROKO SN04-N,SN04-P接近开关,ROKO SN04-N,SN04-P接近开关,ROKO SN04-N,SN04-P接近开关
产品分类:离散传感器 物联网 接近开关 感知层 位置检测
品牌:产品介绍
Output mothod 輸出模式 | NPN N.O. | – | – | SN04-N | SN04-ND |
NPN N.C. | – | – | SN04-N2 | SN04-N2D | |
PNP N.O. | – |
– | SN04-P |
SN04-PD | |
PNP N.C. | – | – | SN04-P2 | SN04-P2D | |
NPN N.O./N.C. PNP N.O./N.C. |
SCR N.O. | SN04-A | SN04-AD | – | – | |
SCR N.C. | SN04-A2 | SN04-A2D | – | – | |
Sensing surface / 檢測方向 | Top surface / 前方 | Top surface / 前方 | |||
Standard sensing object / 標準檢測物 | Iron 18 x1 8 x 1mm | Iron 18 x1 8 x 1mm | |||
Sensing distance / 檢出距離 | 4 mm | 4 mm | |||
Secure sensing distance / 建議距離 | 0 to 3.2 mm | 0 to 3.2 mm | |||
Hysteresis / 遲滯 | ≦ 10 % of sensing distance | ≦ 10 % of sensing distance | |||
Response time / 反應時間 | 50 ms Max. | 2 ms Max. | |||
Operating voltage / 工作電壓 | AC90 ~ 260 V | DC10 ~ 30 V | |||
Current consumption / 消耗電流 | 2 mA Max. | ≦ 8 mA no-load | |||
Load current / 負載電流 | 5~100 mA Max. | 100 mA Max. at DC 30V | |||
Leakage current / 漏電流 | ≦ 2.0mA no-load | ≦ 1.1 mA no-load | |||
Residual voltage / 殘餘電壓 | ≦ AC 4V | ≦ DC 1.5V | |||
Insulation resistance / 隔離阻抗 | 20M Ω min. (DC500V) | 20M Ω min. (DC500V) | |||
Voltage withstandability / 絕緣耐壓 | AC1000V 60Hz for 60 Sec. | AC1000V 60Hz for 60 Sec. | |||
Operating temperature / 工作溫度範圍 | -20℃ ~ + 60℃ | -20℃ ~ + 60℃ | |||
Protection degree / 防水等級 | IP 66 | IP 66 | |||
Wiring method / 出線方式 | Pre-wire Ø4.2 x 2M/2-wires |
M8 pigtailed type /M8 接頭15cm 電線式 | Pre-wire Ø4.2 x 2M/3-wires |
M8 pigtailed type /M8 接頭15cm 電線式 | |
Weight / 重量 | Approx. 56g | Approx. 15g | Approx. 60g | Approx. 18g | |
Honeywell SZL-WLC-A,SZL-WLC-B 限位开关
霍尼韦尔 SZL-WL-A,SZL-WL-B 行程开关
霍尼韦尔 SZL-VL-I,SZL-VL-B 行程开关
霍尼韦尔 SZL-VL-A 行程开关
honeywell SZL-VL-S-J,SZL-VL-J行程开关
