嘉兆科技 4040A PXI 仪器工作放大器
The Model 4040A is a Fast PXI Instrumentation Amplifier designed to work with PXI digitizers and oscilloscopes. The Model 4040A offers 100V differential inputs with 70dB of CMRR. The bandwidth ranges from DC-50 MHz with programmable gain, attenuation,
产品分类:品牌:
Differential 100 V Common Mode Input
DC-50 MHz Bandwidth
AC/DC Coupling
Programmable Attenuation/Gain/Offset
9 nV/vHz Input Noise
50 Output
The TEGAM Model 4040A easily connects your digitizer or analog inputs to real-world signals ranging from 100 V supply voltages to millivolt detector outputs. Elevated voltages and noisy environments present a barrier to making acceptable measurements with common digitizers that are limited by input impedance and voltage levels. Your investment in a high performance digitizer is significantly enhanced by having an instrumentation grade connection to the point of measurement.
The TEGAM Model 4040A comes complete with an IVI-compliant driver for LabVIEW, Microsoft C++ and Visual Basic. In addition, an interactive front panel application provides manual control of all of the board’s features.
Chart HALT/HASS试验箱解决方案特点介绍
Chart真空绝热管道
电池管理系统测试平台
动力电池充放电系统
直流马达测试方案
