集智达 VTC 7110车载通讯工业计算机
2012/9/14 10:47:13
内建Intel® Core? i7 2610UE 1.5GHz处理器 支持2个Ethernet LAN端口 可移动2.5" SSD 可选的CAN bus,支持SAE J1939 或 J1708 可选的隔离数字输入输出 9~36V 宽压直流电源输入 智能电源引擎功能, 延迟和低压保护 可选的4路 PoE 坚固的无风扇设计,符合MIL-810F抗震标准
产品分类:工控机 工控机整机 专用机
品牌:集智达智能
芯片?
QM67
CPU
内存
1个204-pin SO-DIMM DDR3 1333,高达4GB
网络扩展
Mini-PCIe槽(PCIe + USB) x 1 (可选WLAN模块)
Mini-PCIe槽(USB) x 1 (可选3.5G模块)
可选蓝牙模块
板载内置的GPS模块或者可选的航位推测GPS
通过可选I/O板扩展
4路PoE, 1个2.5" SSD
16路隔离的数字输入输出, 1个DB9为SAE J1939 或 SAE J1708
前置I/O界面
5 x LED's for power stand-by (on power button), power status, HDD, WLAN/ HSDPA and GPIO
1 x power button
2 x USB port
2 x SIM card socket
1 x system reset button
1 x Mic-in, 1 x Line-out
1 x CFast with protection cover
1 x accessible 2.5" SSD tray (HDD)
后置I/O界面
2 x USB 2.0 host type A connector
1 x VGA
1 x DB26 pin connector (LVDS, USB,12V, 5V) or optional with DVI-D
2 x RJ45 with LEDs for 10/100/1000Mbps Ethernet
2 x DB9 male connector (1 x RS-232;
1x 485/422) or optional with CAN bus to replace one RS-232 1 x DB9 female connector for GPIO
Input (source type; 0~30V) Output (sink type; 20mA max) 1 x Mic-in and 1 x Line-out 12V@4A DC output connector (TBD) 2 pin switch power output directly from vehicle source (@4A)
Reserved for 4 optional antenna hole for GPS/ WWAN/ WLAN 1 x 3-pin power input connector (9~36V DC-in)
存储扩展
1 x 2.5" SATA tray
1 x CFast
电源管理
Selectable boot-up & shut-down voltage for low power protection by software
Setting 8-level on/off delay time by software
Status of ignition and low voltage status can be detected by software
Support S3/ S4 suspend mode
尺寸
VPC 7110-B:
260mm (W) x 176mm (D) x 50mm (H) (10.24"x 6.93"x 1.97") 2.19 Kg (4.82 Lb) VPC 7110-C4 and VPC 7110-D1
260mm (W) x 176mm (D) x 73.6mm (H) (10.24"x 6.93"x 2.9") |
构造
铝制机箱,无风扇设计
运行环境
操作温度:
空气流通:-30°C 到 50°C 存储温度: -35°C 到 85°C
相对湿度: 10% 到 90% (非凝结)
振动(random): 2g@5~500 Hz with SSD (操作时)
振动(with SSD):
操作: MIL-STD-810F, Method 514.5, Category 20, ground vehicle- highway truck 存储: MIL-STD-810F, Method 514.5, Category 24, integrity test 冲击(with SSD): 操作: MIL-STD-810F, Method 516.5, Procedure I, trucks and semi-trailers=20g Crash hazard: MIL-STD-810F, Method 516.5, Procedure V, ground equipment=75g |
防护等级
可选IP65
认证
CE
FCC Class A
e13 Mark
集智达网络安全计算机——网闸篇
集智达PCIe扩展网卡4个千兆电口国产网卡芯片标准竖插扩展网卡
集智达重磅推出基于国产化X86架构处理器的高性能网络安全计算机
集智达CTC设备为国铁建设助力
集智达推出基于国产化平台的边缘服务器
