I/O 接口-前面板
1x VGA Output
DB15x1, support analog monitor with pixel resolution up to 2048 x 1536@75 Hz 2x RS232 COM Port
DB9 x 2, support 115.2 Kbps baud rate 2x USB Port
2x USB 2.0 ports, 500mA per port, covered with plastic cover to against the dust 1x Mic-in & 1x Speaker-out
· Audio controller: High Definition Audio Controller, Realtek: ALC888-GR
· 1x Speaker-out, Dia. 3.5mm phone jack, covered with plastic cover to against the dust
· 1x Mic-in, Dia. 3.5mm phone jack, covered with plastic cover to against the dust 1x 10/100 M12 LAN Port
· LAN Controller: Intel® WG82574L LAN controller x 1
· Support Wake on LAN and boot from LAN function?? Wireless Communication
· 1x External accessible SIM card socket
· 1x Mic-in for wireless communication use
· 1x Speaker-out for wireless communication use
· 2x Antenna holes (for 3G/3.5G mobile wireless module) LEDs
· 1x LED for power status
· 1x LED for HDD status
· 1x LED for 10/100 LAN Link
· 1x LED for 10/100 LAN Active DC Input
· 24V as the nominal (Range: 16.8V ~ 30V)
· Ignition signal input (24V, nominal; 0~10.5V = off, rest = on)
· 500V Isolated design on DC Input
· 1x External fuse 1 x Mic-in & 1 x Speaker-out
· Audio controller: High definition audio controller, Realtek: ALC888-GR
· 1 x Speaker-out, Dia. 3.5mm phone jack, covered with plastic cover to against the dust
· 1 x Mic-in, Dia. 3.5mm phone jack, covered with plastic cover to against the dust 1 x 10/ 100 M12 LAN Port
· Support wake on LAN and boot from LAN function Wireless communication
· 1 x External accessible SIM card socket
· 1 x Mic-in for wireless communication use
· 1 x Speaker-out for wireless communication use
· 2 x Antenna holes (for 3G/ 3.5G mobile wireless module) LEDs
· 1 x LED for power status
· 1 x LED for HDD status
· 1 x LED for 10/ 100 LAN link
· 1 x LED for 10/ 100 LAN active DC Input
· Nominal Voltage: 24V (Range: 16.8V ~ 30V)
· 1 x External fuse
环境
Operating temperature
Ambient with air: -25°C to 55°C (EN50155 Class T1) Storage temperature: -40°C to 80°C Damp heat test: 95% at 55 °C, compliance with EN50155 Relative humidity: 0% to 90% (non-condensing) Vibration (Random): Compliance with EN61373 Category 1, Class B Shock: Compliance with EN61373 Category 1, Class B
