集智达 MRC 2200强固弄平板电脑
2012/10/15 9:49:22
8" LCD (LED背板指示VGA ) 采用 5-wires 阻抗触摸屏 Intel® Atom? N450 1.6GHz 处理器 完整坚固的MIL-STD810F 和IP54等级 抗跌落高度: 4 feets WLAN/WWAN/Bluetooth无线连接 无线网络支持WiFi 802.11 b/g/n WWAN 支持GSM/GPRS/HSDPA/WCDMA (可选) 集成 GPS 模块支持 RF, 通过支架的外部连接器 集成 激光条码扫描仪(1D/2D) 或 HF type RFID (可选) 可集成 2M 像素的 Camera 在后面板或前面板 (optional) 1 x 导航键和4 x 可编程功能键 电池寿命可长达 4-6 小时
产品分类:工控机 工控机整机 平板电脑(PPC)
品牌:集智达智能
CPU
Intel® Atom? N450 1.6GHz processor
667MHz FSB
芯片组
Intel® System Controller Hub ICH8M
内存
1GB DDR2 SDRAM- 667MHz, support up to 2GB (optional)
存储
8GB Solid State Drive/ SATA interface, support up to 64GB
视频
Intel® high definition audio
AC '97 compatible
2 x 2W built-in speakers
1 x external Mic-in and 1 x external Line-out
1 x Internal microphone
图像
8" TFT LCD with LED backlight
Resolution: 800 x 600 pixels (SVGA) Luminance: 320nits Contrast ratio: 500:1 5-wries resistant touch screen
Auto dimming via ambient light sensor
I/O 接口
2 x USB 2.0 type A port; 1 x mini USB connector
1 x MIC-in
1 x Line-out
1 x 19V DC power input
1 x Docking connector
通讯
IEEE 802.11 b/g/n Wi-Fi module with built-in antenna Bluetooth module class 2 v2.1 + EDR (optional)
WWAN support of GSM/ GPRS/ HSDPA/ WCDMA (optional)
Data Capture
GPS receiver with built-in internal antenna (optional)
2M pixel CMOS camera
HF RFID reader compliant with ISO14443A/B and ISO 15693 (optional)
1D/ 2D laser barcode engine (optional)
Fingerprint Sensor
指示灯和按钮
Four color LED indictors - power on/off, battery, WLAN and HDD
Four programmable function keys
Five buttons – navigation key, power button, wireless switch button, camera shot button and barcode scanner button
电源输入
Power input voltage: DC 19V/ 3.42A
AC adapter: 100V-240V AC, 50Hz/60Hz
Rechargeable lithium ion smart battery pack: 2600 mAh@11/1V, 28.86W/hr; support hot swap (optional)
尺寸规格
296mm (W) x 214mm (H) x 50mm (D) with rubber
280mm (W) x 205mm (H) x 37mm (D) without rubber
Weight: 1.44Kg with rubber; 1.2Kg without rubber
构造
Plastic housing (ABS + PC)
Color: Black
环境
Operating Temperature: -20°C to 50°C
Storage Temperature: -30°C to 60°C
Rel. Humidity: 0% to 95%
防护等级
IP 54
Compliance with MIL-STD-810F
认证
CE approval
FCC Class B
集智达网络安全计算机——网闸篇
集智达PCIe扩展网卡4个千兆电口国产网卡芯片标准竖插扩展网卡
集智达重磅推出基于国产化X86架构处理器的高性能网络安全计算机
集智达CTC设备为国铁建设助力
集智达推出基于国产化平台的边缘服务器
