集智达 MRC 2100-E强固型平板电脑
2012/10/15 9:53:26
Intel® Atom? CPU 1.1GHz 和 1.6GHz (2W~2.4W) 内建 WiFi 802.11/b/g/n/Bluetooth 模块/GPS 内建移动宽带模块,支持 GSM/GPRS/HSDPA/WCDMA (可选) 阳光下易读和显示 内建1D/2D 激光条码扫描仪或 RFID (可选) 1 x 导航键和 4 x 可编程功能键 坚固设计- 适用多种严苛环境规格 GPS 支持 RF passing 到外接的天线,通过车载底座配件
产品分类:工控机 人机界面 平板电脑 工控机整机 平板电脑(PPC)
品牌:集智达智能
CPU
Intel® Atom? processor 1.1GHz/ 1.6GHz with 512 KB on-die L2 cache, 400MHz/ 533MHz FSB
芯片组
Intel® System Controller Hub US15W (single chip integrated graphics and I/O controller)
内存
1GB DDR2 SODIMM 667MHz, support up to 2GB (optional)
存储
8GB Solid State Drive/ SATA interface, up to 64GB (optional)
音频
ALC888-VC2-GR HD Codec
AC '97 Compatible
2 x 2w built-in speaker
1 x external Mic-in and 1 x external Line-out
显示
8.4" TFT LCD with CCFL backlight; Resolution: 800 x 600 (SVGA); Luminance: 400 nits; Contrast Ratio: 500:1
Touch Screen: Analog Resistive 4 wire daylight readable touch screen
Auto dimming via ambient light sensor
I/O
2 x External USB 2.0 port; 1 x Mini USB (Client) 1 x Mic-in and 1 x Line-out 1 x 19V DC power input
通讯
Bluetooth Module class 2 V 2.1 + EDR
IEEE 802.11 b/ g/ n Wi-Fi Module with built-in antenna
WWAN module support of GSM/ GPRS/ HSDPA/ WCDMA (optional)
Data Capture
GPS receiver with built-in internal antenna
2M pixel CMOS camera
HF RFID reader compliant with ISO14443A/B and ISO 15693 (optional)
1D/ 2D laser barcode engine (optional)
Fingerprint Sensor
电源输入
Power Input Voltage: DC 19V/3.42A
Power Output: 65W (Max)
Internal Battery: Rechargeable 3 Cell (3S1P) Lithium Ion Smart Battery Pack(2600 mAh@11.1V, 28.86W/hr) Over Charge Protection, Over Discharge Protection, Over Current and Output Short
指示器和按钮
Power on/off Status (Blue LED on power switch)
Battery Status (Green LED: Battery Discharged/Glows Orange: charging/fully charged: Battery LED turn off)
Battery Low (Battery LED: Glows Green and Power LED Glows Blue) Wireless on/off LED (Orange LED on Wireless on/off switch ,Glows Orange is being accessed)
Hard Disk Drive Status (Green LED: Glows Green HDD is being accessed)
4 x Programmable function keys
Navigation key
Power on/off switch
Camera snap shot button
Barcode scanner button
体积
289mm (W) x 214mm (H) x 46mm (D) with Rubber
280mm (W) x 205mm (H) x 37mm (D) without Rubber
Weight: 1.65Kg with Rubber; 1.35Kg without Rubber
构造
Plastic housing (ABS + PC)
Color: Black
环境
Operating Temp: -20°C to 50°C
Storage Temp: -30°C to 60°C
Rel. Humidity: 5% to 95%
Rugged Grade
IP54
4 feet drop to polywood
Compliant with MIL-STD-810F
认证
CE approval
FCC Class B
集智达网络安全计算机——网闸篇
集智达PCIe扩展网卡4个千兆电口国产网卡芯片标准竖插扩展网卡
集智达重磅推出基于国产化X86架构处理器的高性能网络安全计算机
集智达CTC设备为国铁建设助力
集智达推出基于国产化平台的边缘服务器
