集智达 NDIS-120多媒体播放器
☆ Intel® Atom N270 Platform ☆ Low Power Consumption ☆ Slim and Fan-less ☆ Dual Independent Display ☆ Hyper-Threading Support ☆ TV Tuner/WLAN Support
产品分类:工控机 嵌入式系统
品牌:集智达智能
CPU |
Intel® Atom N270 1.6GHz CPU onboard |
芯片组 |
945GSE + ICH7M Intel® GMA 950 Graphic Engine |
前面板I/O |
1 x LED Power-On 1 x LED Storage |
后面板I/O |
1 x DB9 RS232 COM port 1 x DB15 VGA port 1 x DVI-D port 4 x USB 2.0 port 1 x Line-out 1 x Line-in 1 x RJ45 with LEDS for 10/100/1000 Mbps Ethernet 1 x Antenna hole for WiFi 12VDC Power In |
存储 |
1 x 2.5" SATA HDD Bay |
扩展 |
1 x Mini-PCIe for optional TV tuner or WLAN module |
尺寸 |
272mm (W) x 195mm (D) x 44mm (H)(10.7" x 7.7" x 1.7") w/o mounting bracket |
电源 |
1 x External 60W AC/DC power adaptor Input: 100~240VAC Output: +12VDC |
环境 |
Operating Temperature: Ambient with air flow from 0°C to 40°C (HDD inside) Storage Temperature: -20°C to 80°C Humidity: 10 to 90% (Non-condensing |
集智达网络安全计算机——网闸篇
集智达PCIe扩展网卡4个千兆电口国产网卡芯片标准竖插扩展网卡
集智达重磅推出基于国产化X86架构处理器的高性能网络安全计算机
集智达CTC设备为国铁建设助力
集智达推出基于国产化平台的边缘服务器
