Carlo Gavazzi瑞士佳乐 RZ3A40D25 三相固态继电器
Carlo Gavazzi瑞士佳乐RZ3A40D25三相固态继电器,输入规格:4.20MA,3-32VDC,10-90VDC,90-280VAC/DC
产品分类:低压电器 控制电器 继电器 固态继电器
品牌:佳乐
外型尺寸:74*103*41
额定电流:25A,50A,90A,110A
功率因数:大于等于0.5
工作温度:负20度至正70度
端子:接线端子
认证/标准:CE-UL-CSA
RZ3A40A25: SSR 3 POLE ZS 24-440V 25A 24-275VAC
RZ3A40A25P: SSR 3 POLE ZS 24-440V 25A 24-275VAC +OTP
RZ3A40A40: SSR 3 POLE ZS 24-440V 40A 24-275VAC
RZ3A40A40P: SSR 3 POLE ZS 24-440V 40A 24-275VAC +OTP
RZ3A40A55: SSR 3 POLE ZS 24-440V 55A 24-275VAC
RZ3A40A55P: SSR 3 POLE ZS 24-440V 55A 24-275VAC +OTP
RZ3A40A75: SSR 3 POLE ZS 24-440V 75A 24-275VAC
RZ3A40A75P: SSR 3 POLE ZS 24-440V 75A 24-275VAC +OTP
RZ3A40D25: SSR 3 POLE ZS 24-440V 25A 4-32VDC
RZ3A40D25P: SSR 3 POLE ZS 24-440V 25A 4-32VDC +OTP
RZ3A40D40: SSR 3 POLE ZS 24-440V 40A 4-32VDC
RZ3A40D40P: SSR 3 POLE ZS 24-440V 40A 4-32VDC +OTP
RZ3A40D55: SSR 3 POLE ZS 24-440V 55A 4-32VDC
RZ3A40D55H33: SSR 3 POLE ZS 24-440V 55A 4-32VDC + HS WAS565M:
RZ3A40D55P: SSR 3 POLE ZS 24-440V 55A 4-32VDC +OTP
RZ3A40D75; SSR 3 POLE ZS 24-440V 75A 4-32VDC
RZ3A40D75P: SSR 3 POLE ZS 24-440V 75A 4-32VDC +OTP
RZ3A40LD25; SSR 3 POLE ZS 24-440V 25A 5VDC
RZ3A40LD40: SSR 3 POLE ZS 24-440V 40A 5VDC
RZ3A40LD55; SSR 3 POLE ZS 24-440V 55A 5VDC
RZ3A40LD75; SSR 3 POLE ZS 24-440V 75A 5VDC
RZ3A60A25: SSR 3 POLE ZS 42-660V 25A 24-275VAC
RZ3A60A25P: SSR 3 POLE ZS 42-660V 25A 24-275VAC +OTP
RZ3A60A40: SSR 3 POLE ZS 42-660V 40A 24-275VAC
RZ3A60A40P: SSR 3 POLE ZS 42-660V 40A 24-275VAC +OTP
RZ3A60A55; SSR 3 POLE ZS 42-660V 55A 24-275VAC
RZ3A60A55H33; SSR 3 POLE ZS 42-660V 55A 24-275VAC + HS WA565M;
RZ3A60A55P; SSR 3 POLE ZS 42-660V 55A 24-275VAC +OTP
RZ3A60A75; SSR 3 POLE ZS 42-660V 75A 24-275VAC
RZ3A60A75P: SSR 3 POLE ZS 42-660V 75A 24-275VAC +OTP
RZ3A60D25: SSR 3 POLE ZS 42-660V 25A 4-32VDC
RZ3A60D25P: SSR 3 POLE ZS 42-660V 25A 4-32VDC +OTP
RZ3A60D40; SSR 3 POLE ZS 42-660V 40A 4-32VDC
RZ3A60D40P; SSR 3 POLE ZS 42-660V 40A 4-32VDC +OTP
RZ3A60D55; SSR 3 POLE ZS 42-660V 55A 4-32VDC
RZ3A60D55P: SSR 3 POLE ZS 42-660V 55A 4-32VDC +OTP
RZ3A60D75: SSR 3 POLE ZS 42-660V 75A 4-32VDC
RZ3A60D75P: SSR 3 POLE ZS 42-660V 75A 4-32VDC +OTP
RZ3A60LD25: SSR 3 POLE ZS 42-660V 25A 5VDC
RZ3A60LD40: SSR 3 POLE ZS 42-660V 55A 5VDC
RZ3A60LD75: SSR 3 POLE ZS 42-660V 75A 5VDC
RZ3A69A75: SSR 3 POLE ZS 42-760V 75A 24-275VAC
RZ3A69D75: SSR 3 POLE ZS 42-760V 75A 4-32VDC
RZ3A69LD75: SSR 3 POLE ZS 42-760V 75A 5VDC
中国台湾KINTON精通接近开关感应器KX-W1
KUDOM库顿单相交流输出固态继电器KSI480D60-L
中国台湾TPC亚鸿接近开关JD-1705E1-C50
VMMORE微秒伺服驱动器ISD300-S25A-043
STUOB思拓邦圆柱形电感式接近传感器HX-1204-E1
