集智达 NDIS-163数字媒体播放器
Intel® Core 2 Duo/Celeron® Platform ☆ Intel® GM 4500MHD Graphic Engine ☆ Compact and Fan-less ☆ Dual Independent Display ☆ WLAN and TV Tuner support
产品分类:工控机 嵌入式系统
品牌:集智达智能
CPU |
Intel® Core 2 Duo/Celeron® family processors with 1066/667 MHz |
芯片组 |
Intel® GM45 Intel® 82801IBM I/O Controller Hub |
内存 |
2 x 240-pin 25° angled DIMM, up to 8GB with un-buffered and Non-ECC DDR3 800/1066 MHz SDRAM |
前面板I/O |
2 x USB 2.0 2 x RS232 GPIO Terminal Port (4 in, 4 out) |
后面板I/O |
1 x +12V DC-in 2 x LED for PW & HDD 1 x ON/OFF Power Switch 1 x VGA 1 x DVI-D 1 x HDMI 2 x USB 2.0 1 x RJ45 with LED for 10/100/1000Mbps Ethernet 1 x SPDIF 1 x Line-out 2 x Antenna hole for WiFi & TV Tuner |
存储 |
1 x SATA 2.5" HDD Bay 1 x u-DOM socket |
扩展 |
1 x Mini-PCIe for optional Wireless LAN module 1 x Mini-PCIe for optional TV tunner module |
尺寸 |
280mm (W) x 210mm (D) x 40.4mm (H) (11" x 8.3" x 1.6") w/o mounting bracket |
结构 |
Top cover made by Aluminum for main heat exchange Chassis made by steel in black |
电源 |
1 x External 96W AC/DC power adapter Input: 100~240VAC Output: +12VDC |
环境 |
Operating Temperatures: 0°C to 40°C Storage Temperature: -40°C to 80°C Humidity: 10 to 90% (Non-condensing) |
集智达网络安全计算机——网闸篇
集智达PCIe扩展网卡4个千兆电口国产网卡芯片标准竖插扩展网卡
集智达重磅推出基于国产化X86架构处理器的高性能网络安全计算机
集智达CTC设备为国铁建设助力
集智达推出基于国产化平台的边缘服务器
