集智达 NDIS 540数字媒体播放器
☆ AMD Athlon 64/64 X2 AM2 Platform ☆ ATI Radeon E2400 GPU ☆ Slim and Compact Design ☆ 4 x DVI/4 x Audio ☆ Dual GbE LAN ☆ 6 x Serial Ports ☆ TV Tuner/WLAN Support
产品分类:工控机 嵌入式系统
品牌:集智达智能
CPU |
Support AMD AM2 Socket Athlon 64/64 X2 series processor |
芯片组 |
AMD M690E/AMD SB600 ATI Radeon E2400 GPU |
内存 |
2 x 240-pin DIMM sockets, support DDR2 800MHz SDRAM memory module up to 4GB |
前面板I/O |
1 x HDD Status LED (Yellow) 1 x Power Status LED (Green) |
后面板I/O |
+12V DC-in 2 x DB9 for RS-232 4 x serial ports (TX & RX only) 4 x USB 2 x RJ45 with LEDs for 10/100/1000Mbps Ethernet 4 x Line-out 4 x DVI (2 x DVI-I and 2 x DVI-D) ATX Power-on switch 1 x Antenna hole for WiFi or TV tuner module |
存储设 |
1 x SATA 2.5" HDD 1 x CF type I/II |
扩展 |
1 x Mini-PCIe for optional WLAN/TV tuner module |
尺寸 |
272mm (W) x 195mm (D) x 44mm (H) (10.7" x 7.7" x 1.7") w/o rubber stand |
电源 |
1 x External 96W AC/DC power adapter Input: 100~240VAC Output: +12VDC |
环境 |
Operating Temperature: Ambient with air flow from 0°C to 40°C (HDD inside) Storage Temperature: -20°C to 80°C Humidity: 10 to 90% (Non-condensing) |
集智达网络安全计算机——网闸篇
集智达PCIe扩展网卡4个千兆电口国产网卡芯片标准竖插扩展网卡
集智达重磅推出基于国产化X86架构处理器的高性能网络安全计算机
集智达CTC设备为国铁建设助力
集智达推出基于国产化平台的边缘服务器
