致昇電子 AXE MC 6位數微電腦型計數器(48x96mm)
■特點(FEATURES) ●最高輸入頻率 10KHz(Accepts input rates up to 10KHz) ●計數速度 50/10000脈波/秒可選擇(Accept input rates 50 or 10000 CPS can be modified) ●四種輸入模式可選擇(加算,減算,加減算,90度相位差加減算) (Four count_ing modes Up,Down,Up/Down, quadrature can be modified) ●90度相位差加減算具有提高解析度4倍功能 (Quadrature sensing up to 4 times resolution) ●輸入脈波具有預設刻度功能(Input scaling multiplied 0.00001 to 9.99999 can be modified) ●計數暫時停止功能(Count_inhibit function(GATE control)) ●3 組警報功能(Three alarm function)(optional) ●15BIT 類比輸出功能(15 bit DAC analog output function)(optional) ●數位RS-485界面(Digit RS-485 interface function)(optional)
产品分类:仪器仪表 数显仪表 显示控制仪表
品牌:产品介绍
( 脈波輸入型式 ) or current sinking (PNP)
● Count_ input trigger levels : HI bias (CMOS) (VIH=7.5V, VIL=5.5V)
( 脈波觸發電位 ) LO bias (TTL) (VIH=3.7V, VIL=2.0V)
● Max.count_rates : <10KHz (up,down,up/down mode)
( 最高輸入頻率) <3KHz (quadrature mode)
● Readout (compare)rang : -199999 to 999999
( 顯示值範圍)
● Output hold time : 0.1 to 99.9 second adjustable
( 輸出動作時間 )
● Output reset type : Manual(N) or automatic (R or C) can be modified
( 輸出復歸方式 )
● Relay contact output : AC 250V-5A, DC 30V-7A
( 繼電器容量 )
● Analog output resolution : 15 bit DAC
( 類比輸出解析度 )
● Response time : < 1/f+10ms(0-90%)
( 輸出反應速度 )
● Output drive capability : < 10mA for voltage mode
( 輸出負載能力 ) < 10V for current mode
<[(V+)-7.5V]/20mA for two-wire mode
● Output ripple (p-p) : < 0.1% F.S.
( 輸出之漣波 )
● RS-485 adress : "01"-"FF"
( 通訊位址 )
● RS-485 baud rate : 19200/9600/4800/2400 selective
( 傳輸速度 )
● RS-485 protocol : Modbus RTU mode
( 通信協議 )
● Display : Red high efficiency LEDs high 14.22mm (.56")
( 顯示幕 )
● Parameter setting : Touch switches
( 參數設方式 )
● Sensor power supply : 12VDC +/-3%(<60mA)
( 感應器電源 )
● Memory mode : Non-volatile E2 PROM memory
(記憶方式 )
● Dielectric strength : 2KVac/1 min. (input/output/power)
( 絕緣耐壓能力 ) 1600Vdc (input/output)
● Operating condition : 0-50℃(20 to 90% RH non-condensed)
( 使用環境條件 )
● Storage condition : 0-70℃(20 to 90% RH non-condensed)
( 存放環境條件 )
● CE EMC Certification : EN 55022:1998/A1:2000 Class A
JASON 5AM-P 4位数类比输入数字显示表
3线电位计变送器
苏州致昇 AXE M2-A13A电表
PT100温度变送器
苏州致昇 AXE MMS-LA12D电表
