集智达 APPC0820T/0820TC触摸屏工业一体机
4:3 8"无风扇LED工业一体机 Intel® Atom? D525, 双核,低功耗CPU 全5-wire触摸屏 双千兆网,双VGA显示/ Line-in/ Line-out/ MIC-in/ PS2 KB/MS USB x 4/ 1 x mini-PCIe 插槽/ 1 x CF
产品分类:工控机 人机界面 图控一体化产品
品牌:集智达智能
面板 | LCD Size: 8", 4:3 Resolution: SVGA 800x600 Luminance: 400cd/m2Contrast ratio: 500 LCD color: 262K Viewing angle: 50(U), 70(D), 70(L), 70(R) Backlight: LED Touch screen: 5-wire resistive (flush panel type) Touch light transmission: 82% Touch interface: USB |
系统 | CPU: Intel® Atom? D525, 1.8GHz BIOS: AMI BIOS System chipset: Intel® ICH8M System memory: 1x 204-pin DDR3 SO-DIMM socket, 1G DDR3 (Default), Support up to 2GB DDR3 800, Non-ECC and Un-buffered Storage: |
后置I/O界面 | APPC 0820TC: |
音频 | AC97 codec: Realtek ALC888 Audio interface: Line out/Line in/MIC-in Audio Jack |
以太网 | LAN chip: dual Intel® 82574L Gigabit LAN Ethernet interface: 10/100/1000 Based-Tx Ethernet compatible |
外观&运行环境 | Color: pantone black IP protection: IP65 front Mounting: panel/ wall/ stand/ VESA 100mm x 100mm Power input: 12V DC Power adapter: Optional AC to DC power adaptor (+12V, 60W) Vibration: |
认证 | CE approval FCC Class A |
集智达网络安全计算机——网闸篇
集智达PCIe扩展网卡4个千兆电口国产网卡芯片标准竖插扩展网卡
集智达重磅推出基于国产化X86架构处理器的高性能网络安全计算机
集智达CTC设备为国铁建设助力
集智达推出基于国产化平台的边缘服务器
