集智达 APPC1720T/1721T触摸屏工业一体机
4:3 17" 无风扇平板电脑 Intel® Atom? D525, Dual Core, 低功耗CPU 完全统一的5线触摸屏 Dual GbE; 2nd display VGA
产品分类:工控机 人机界面 图控一体化产品 工控机整机 平板电脑(PPC)
品牌:集智达智能
面板 | LCD Size: 17", 4:3 Resolution: SXGA 1280x1024 Luminance: 380cd/m2 Contrast ratio: 1000 LCD color: 16.7M iewing Angle: 80(U), 80(D), 85(L), 85(R) Backlight: CCFL Touch screen: 5-wire resistive (flush panel type) Touch light transmission: 81% Touch interface: USB |
系统 | CPU: Intel® Atom? D525, 1.8Hz BIOS: AMI BIOS System chipset: Intel® ICH8M System memory: support up to 2GB DDR3 800 (Optional) SSD: one CF socket by IDE support Type I/II compact Flash card Hard drive bay: optional 2.5” SATA HDD or SATA DOM Watchdog timer: reset: 1 sec~ 255 min and 1 sec or 1 min/ step H/W status monitor: Monitoring system temperature, and voltage Expansion: 2x Mini-PCIe NEXCOM Xcare platform system management supported |
后置 I/O | CAN BUS (for APPC1721T Optional) GPIO (for APPC1721T only): 4 x digital in / 4 x digital out COM #1: RS232/422/485 (APPC 1721T w/ 2.5kv isolated) COM #2: RS232/422/485 (APPC 1721T w/ 2.5kv isolated) COM #3 & COM #4 (for APPC 1721T only): 2x RS232 Ethernet: 2 x RJ45 2nddisplay VGA port: 1 x DB15 Audio port: 1 x Line out; 1 x Line in; 1 x MIC-in USB: 4 x USB 2.0 PS2 keyboard/ mouse Power switch Reset button |
音频 | AC97 codec: Realtek ALC888 Audio interface: Line out/Line in/MIC-in Audio Jack |
以太网 | LAN chip: dual Intel® 82574L Gigabit LAN Ethernet interface: 10/100/1000 Based-Tx Ethernet compatible |
机械构造&环境 | Color: pantone black IP protection: IP65 front Mounting: panel/ wall/ stand/ VESA 100mm x 100mm Power input: 12V~ 30V DC Power adapter: Optional AC to DC power adaptor (+12V, 60W) Vibration: Operating temperature: -5°C to 50°C Storage temperature: -20°C to 75°C Operating humidity: 10%~90% relative humidity, non-condensing Dimension: 410.4 x 340.4 x 75.79 mm Weight: 6.3 Kg |
Certifications | CE approval FCC Class A |
集智达网络安全计算机——网闸篇
集智达PCIe扩展网卡4个千兆电口国产网卡芯片标准竖插扩展网卡
集智达重磅推出基于国产化X86架构处理器的高性能网络安全计算机
集智达CTC设备为国铁建设助力
集智达推出基于国产化平台的边缘服务器
