集智达 1045T/1046T触摸屏工业一体机
2012/11/20 11:26:40
Panel LED Size: 19", 4:3、 Resolution: SXGA 1280x1024 Luminance: 350cd/m2 Contrast ratio: 1000 LCD color: 16.7M Viewing Angle: 80(U), 80(D), 85(L), 85(R) klight: LED Touch Touch screen: 5-wire resistive (flush panel type) Touch light transmission: 81%
产品分类:工控机 人机界面 图控一体化产品 工控机整机 平板电脑(PPC)
品牌:集智达智能
Panel
LED Size: 19", 4:3、
Luminance: 350cd/m2
LCD color: 16.7M
klight: LED
Touch
uch interface: USB
System
CPU: On-board Intel® Atom? Dual Core processor D2550, 1.86GHz, 1M L2 Cache
BIOS: AMI BIOS
System chipset: Intel® NM10 Express chipset
System memory: 2x 204-pin DDR3 SO-DIMM socket, 1G DDR3 (Default), Support up to 4GB DDR3-800/1066, Non-ECC and Unbuffered
Storage Device
- 1x external locked CFast socket
- 1x hard drive bay: optional 1x 2.5” SATA HDD or 1x SATA DOM Watchdog timer: Watchdog timeout can be programmable by software from 1 second to 255 seconds and from 1 minute to 255 minutes (Tolerance 15% under room temperature 25°C)
H/W status monitor: Monitoring system temperature, and voltage
Expansion: 2x Mini-PCIe sockets (support optional WiFi or 3.5G module)
Panel backlight control button: Increase brightness / decrease brightness / Backlight On/Off (For APPC1931T only)
Audio
Ethernet: 2 x RJ45
2nd display VGA port: 1 x DB15
Audio port: 1 x Line out; 1 x Line in; 1 x MIC-in
USB: 4 x USB 2.0
PS2 keyboard/ mouse
Power switch
Reset button
COM #1: RS232/422/485 w/RI or 5V selection
COM #2: RS232/422/485 w/RI or 12V selection
For APPC1931T only
DIO w/ 2.5kv isolated:
4x Digital Input (Source type) - Input Voltage (Dry Contact): Logic 0: Close to GND - Logic 1: Open - Input Voltage: Logic 0: 3V max - Logic 1: +5V ~ +30V 4x Digital Output (Sink type)
- Output Voltage: 3.6V ~ 5V - Sink current: 200 mA max. per channel GPIO: 2 x digital in / 2 x digital out
COM #1: RS232/422/485 w/ 2.5kv isolated
COM #2: RS232/422/485 w/ 2.5kv isolated
COM #3: RS232 w/ RI or 5V selection
COM #4: RS232 w/ RI or 12V selection
Audio
AC97 codec: Realtek ALC886-GR
Audio interface: Line out/Line in/MIC-in Audio Jack
Ethernet
LAN chip: dual Intel® 82574L Gigabit LAN
Ethernet interface: 10/100/1000 Based-Tx Ethernet compatible
Certifications
Color: pantone black\RAL 15 00 front bezel w/ Pantone 400C\RAL 090 80 10 metal style membrane、
IP protection: IP65 front
Mounting: panel/ wall/ stand/ VESA 100mm x 100mm
Power input: 12V~ 30V DC
Power adapter: Optional AC to DC power adaptor (+12V, 60W)
Vibration: - IEC 68 2-64 (w/ HDD)
- 1Grms @sine, 5~500Hz, 1hr/axis (HDD Operating) - 2Grms @sine, 5~500Hz, 1hr/axis (CFast Operating) - 2.2Grms @ random condition, 5~500Hz, 0.5hr/axis (Non-operating) Shock:
- IEC 68 2-27
- HDD: 20G@wall mount, half sine, 11ms Operating temperature: -5°C to 50°C
Storage temperature: -20°C to 75°C
Operating humidity: 10%~90% relative humidity, non-condensing Limits to be at 90% RH at max 50°C
Dimension: 457.64 x 379.24 x 61.25 mm
Weight: 6.5 Kg
Certifications
CE approval
FCC Class A
集智达网络安全计算机——网闸篇
集智达PCIe扩展网卡4个千兆电口国产网卡芯片标准竖插扩展网卡
集智达重磅推出基于国产化X86架构处理器的高性能网络安全计算机
集智达CTC设备为国铁建设助力
集智达推出基于国产化平台的边缘服务器
