OKAYA LE系列安规电容
聚丙烯材料的薄膜电容抗噪音干扰OKAYA安规电容额定电压275V小尺寸
产品分类:工控元器件 无源元件(电阻/电容/电感)
品牌:OKAYA
特点:
Features
1.聚丙烯材料薄膜电容
2.额定电压275V交流
3.小尺寸
4. IEC/EN 60384-14: 2005 class X2
Applications
Safety Standard | File No. |
UL :UL1414, UL1283 | E47474, E78644 |
cUL :C22.2 No.1, C22.2 No.8 | |
SEMKO-ENEC :IEC/EN 60384-14: 2005 | SE/0142-1 |
The "ENEC" mark is a common European product certification mark based on testing to harmonised European safety standard. The mark with #14 stands for SEMKO.
主要设计用来为电气产品在电力传输过程中减少噪音干扰
ions
Rated Voltage 275VAC (UL, cUL: 250V)
Safety Standard | Class | Model Number | Capacitance μF±10% | Dimensions | Dissipation Factor | Test Voltage | Insulation Resistance | ||||
W | H | T | F | d | |||||||
X2 | LE103 | 0.01 | 12.0 | 10.5 | 4.5 | 10.0 | 0.6 | C≤1μF 0.003max. (f=10kHz) C>1μF 0.002max. (f=1kHz) | Line to Line C≤2.2μF 1,250VAC 50/60Hz 60sec C=3.3μF 1,000VAC 50/60Hz 60sec Line to Case 2,000VAC 50/60Hz 60sec | Line to Line 103~334 15,000MΩmin. 474~225 5,000Ω?Fmin. Line to Case 100,000MΩmin. (at 100VDC) | |
LE153 | 0.015 | ||||||||||
LE223 | 0.022 | ||||||||||
LE333 | 0.033 | 11.5 | 5.5 | ||||||||
LE473 | 0.047 | 17.0 | 11.0 | 5.0 | 15.0 | ||||||
LE683 | 0.068 | ||||||||||
LE104 | 0.1 | 11.5 | 5.5 | ||||||||
LE154 | 0.15 | 14.0 | 6.5 | ||||||||
LE224 | 0.22 | 15.0 | 8.0 | ||||||||
LE334 | 0.33 | 17.5 | 17.5 | 9.5 | 0.8 | ||||||
LE474 | 0.47 | 25.5 | 8.5 | 22.5 | |||||||
LE684 | 0.68 | 19.5 | 10.5 | ||||||||
LE105 | 1.0 | 22.0 | 12.0 | ||||||||
LE155 | 1.5 | 30.5 | 24.5 | 15.0 | 27.5 | ||||||
LE225 | 2.2 | 28.0 | 18.0 | ||||||||
LE335 | 3.3 | 30.0 | 27.5 |
Operating Temperature: -55~+100°C
立即报名电子行业年度大趴,已有万名行业精英注册登记!
SII LTP02热敏式打印机芯
SII LTP01热敏式打印机芯
SII CAPD245/345热敏式打印机芯
SII LTPD245/345热敏式打印机芯
