关键字: | 多媒体计算机,高清播放器、高清视频主机 |
产品分类: | 工控机 工控机配件 显示产品 |
品牌: | 亚华兴 |
- 产品简介:
- YHX MTX00多媒体终端系列是北京亚华兴科技有限公司自主设计和生产的一款全新的终端机,特别适合行业的多媒体信息发布系统、医疗多媒体信息化系统及教育信息化系统。
System |
APU |
AMD FT1 APU |
(2-Core@1.0G@9W, 2-Core@1.6G@18W, 1-Core@1.2G@9W) |
Chipset FCH |
AMD FCH A50M |
System Memory |
One 204-pin SODIMM supprt up to 4 GB DDR3-1066 SDRAM |
Onboard memory up to 4GB DDR3-1066 |
Expansion |
1 MiniPCI-E |
I/O |
Front Panel I / O |
1 x VGA |
1 x HDMI |
1 x RJ-45 |
2 x USB |
1 x ESATA+USB 二合一 |
1 x DC输入(12V) |
1 x DC输出(5V) |
Front Panel I / O |
2 x USB |
1 x LED指示灯 |
1 x 麦克输入 |
1 x 音频输入 |
1 x 音频输出 |
1 x 电源按键 |
Internal I / O |
2 x SATA 7PIN |
1 x SATA 22PIN |
1 x 风扇插座 |
1 x VGA 针座(WF1x13) |
1 x LVDS 针座( Pitch 2.0mm 20-pin Header) |
2 x 喇叭针座(WF1x2,1.25mm,2.1 W/Ch Into 4 Ω) |
1 x SPDIF Header |
1 x 12V&5V Wafer(WF1X4,2.5mm) |
1 x 12V Wafer(WF1x2,2.0mm)ERdio Header. RS422/RS485 |
2 x 5V Wafer(WF1x2,2.0mm+WF1x2,1.25mm) |
Display |
APU(FUSION) |
DirectX®11 graphics with UVD 3.0 |
Resolution |
CRT Mode: 2048x1536 @85Hz(4:3), 2560x1440 @75Hz(16:9), 2456x1536 @60Hz(16:10) |
HDMI Mode: 720p,1080p |
Dual Display |
CRT + LVDS, CRT + HDMI, HDMI + LVDS |
LVDS |
Single 18-bit LVDS |
Audio |
HD Codec |
Realtek Azalia ALC662 5.1-CH Audio |
Audio Interface |
Line out(Front) ,Line in(SURR), Mic in(CEN/LFE) |
Ethernet |
LAN |
1 x RTL8111E 10/100/1000Mbps LAN |
Ethernet Interface |
10/100 Base-Tx Fast Ethernet Compatible |
10/100/1000 Base-Tx Gigabit Ethernet Compatible |
Power Requirement & Mechanical |
Power Requirement |
12V/5A Adapter in |
Form Factor |
156*123*35(长宽高) |
