集智达 SBC--5956 5.25"主板
2012/12/27 11:07:29
支持Intel® Core? 2 Duo, Celeron® M 处理器 Intel® GM45 with GMA4500MHD 千兆以太网 2x 240-pin DDR3 DIMM 插槽, 可达 8 GB non-ECC 1066 MHz DRAM 2x Intel® 82574L PCI Express 千兆以太网 1x Realtek ALC888 HD CODEC 6x USB 2.0, 4x Serial port , 4x SATA and 1x Parallel port 1x PCIe x16 Slot/ 1x PCIe x4 Slot/ 1x PCI slot
产品分类:嵌入式系统 物联网 单板电脑 应用层 嵌入式应用
品牌:集智达智能
CPU
Intel® Core? 2 Quad (Q9100 2.26GHz) (non longevity CPU) Intel® Embedded Processor List (Intel® Longevity CPU): Intel® Core? 2 Duo (T9400 2.53GHz); Intel® Celeron® 575 2.0GHz
内存
2 x 240-pin DDR3 DIMM Socket, up to 4GB non-ECC 1066MHz DRAM
芯片组
Intel® GM45 Intel® ICH9-M
BIOS
Award System BIOS PnP and ACPI support 8M bits SPI ROM
板载 LAN
2x Intel® 82574L PCI Express GbE Support PXE and Wake on LAN (When 5Vsb available)(LAN1,LAN2 both) 2x RJ45 w/ LED
图像
Intel® GM45 integrated GMA4500MHD Graphic engine Analog Interface: Resolution up to 1600x1200 at 85 Hz, 2048x1536 at 75Hz 1x DB15 port LVDS Interface: Support 18-bit single and dual channel LVDS, Resolution up to 1600 x 1200 CCFL Interface: 1x CCFL for Panel Backlight Inverter
音频
Realtek ALC888 HD CODEC 1x Mic-in / 1x Line out
扩展
1x PCIe x16 1x PCIe x4 1x PCI
I/O 接口
串口: 4x COM support RS232 only 并口: 1x 26-pin box header USB 2.0: 6x ports, 2x edge ports, 2 ports by JST, 1x pin header for uDOM 8 GPIO lines via header (GPI 0 ~ 3 and GPO0 ~ 3) TTL Level (0/5 V) On-board Power LED and HDD Active LED Pin Header 1x 4-pin and 1x 3-pin Fan connector 1x PS/2 KB/MS Jack On board Buzzer / SMBus2.0 /Reset SW
看门狗定
WDT can be programmable by Software from 1 sec to 255 sec and from 1 min to 255
时器
minutes (Tolerance 15% at 25°C)
存储设置
4x SATA 插槽
系统监视器
Monitoring of 5 voltages and 2 temperatures 5 Voltage (+5V, Vcore , +12V , +3.3V , +1.5V) 2 Temperatures (CPU, External Temperature) 2 fan speed monitor (CPU , system)
电源需求
Supports both AT and ATX Mode (default setting is AT mode) ATX mode: 2x5pin ATX power connector w/ +12V/ 12V/+5V/5Vsb Power In for EBC550 2x2pin power connector +12V Power In for PCIe x16 Card At ATX Mode, the BIOS setting is as follow: POWER -SUPPLY TYPE: [ATX]AUTO PWR-FAILURE RESUME: [ON] AT mode:2x5pin ATX power connector w/ +12V/-12V/+5V Power In for EBC550 No Power On push Button, Software Shutdown function and LAN remote wake up
尺寸规格
5.25" form factor / 203mm (L) x 146mm (W) (7.9"x5.7")
环境
操作温度: 0°C - 60°C 存储温度: -20°C - 85°C 湿度: 10% - 90%, 无凝露
认证
CE approval FCC Class A
集智达网络安全计算机——网闸篇
集智达PCIe扩展网卡4个千兆电口国产网卡芯片标准竖插扩展网卡
集智达重磅推出基于国产化X86架构处理器的高性能网络安全计算机
集智达CTC设备为国铁建设助力
集智达推出基于国产化平台的边缘服务器
