以太网界面 |
| DSSS(802.11b), OFDM(802.11g) |
| -71 dBm @ 54 Mbps, -84 dBm @ 11Mbps |
| 最大54 Mbps (auto fallback: 54,48, 36, 24, 18, 12, 11, 9, 6, 5.5, 2, 1 Mbps) |
| 1个10/100BaseTX, 自适应MDI/MDI-X |
串口通讯界面 |
| RS-232, RS422, 2/4-wire RS485 |
| odd, even, none, Space, Mark |
| TxD, RxD, RTS, CTS, DTR, DSR, GND, DCD |
| XON/XOFF, RTS/CTS, DTR/DSR |
性能 |
| IP, TCP, UDP, ICMP, DHCP, ARP/RARP, SNMP, HTTPS, SSH, SNTP, SMTP |
| Power 1/Power 2: Startup(红灯); Ready(绿灯) 有线 : 10M Link(橙色灯), 100M Link(绿灯) 无线: 连线质量高(绿灯), 连线质量低(橙色灯) 串口: 发送数据(绿灯), 接收数据(橙色灯) |
| JetPort Commander, HTTPS, SSH |
| Real COM, Virtual COM, TCP Server, TCP Client, TCP Tunnel, UDP |
| WEP 64-bit/128-bit数据加密, WPA Personal mode (AES/TKIP) |
| RFC1213 MIB II, RFC1317 RS232_like, SNMP Trap |
| 冷启动/热启动,登录失败,IP及密码变更,访问密码锁死,串口DCD/RI/DSR/CTS状态变化,串口连接/断连 |
Windows工具 |
| 设备检索,Auto IP,网络设置(有线和无线),设备及串口配置监控,报警设置,固件升级,设置备份/还原,批量设置向导 |
| TCP Alive Check Timeout, Inactivity Idle Timeout, Performance mode, Delimiter, Force TX Timeout, Force TX interval time |
| JetPort Commander: 批量IP设置,批量固件升级,批量设置备份/还原,RCOM, VCOM及TCP Tunnel设置向导 |
电源需求 |
| PWR1: 12~48VDC电源接线端子 PWR2: 12~48VDC电源插孔,适用电源适配器 |
| 1 KV Burst (EFT), EN61000-4-4 0.5 KV Surge, EN61000-4-5 |
机械规格 |
| 96.1mm(W)x124mm(D)x29.6mm(H) |
| FCC Class A, CE Class A, RoHS |
工作环境 |
