艾讯宏达最新推出板载i5处理器Mini-ITX主板SYS76988VGGA。板载英特尔i5-3337U处理器,采用英特尔HM76芯片组;2个英特尔PCI-E千兆网络控制器;1个24bit双通道LVDS,支持双显示;2 个Mini PCIe扩展槽。SYS76988VGGA适合于轨道交通、高效能智能交通应用、车载领域...
详细规格:
>> System
Processor Onboard Intel i5-3337U (1.8GHz,17W,2C/4T) Processor(Ivy bridge)
Chipset Intel HM76 chipset
DRAM 2 x 204pin SO-DIMM DDR3 1600/1333MHz up to 16GB
BIOS AMI uEFI BIOS (16Mb SPI flash ROM)
Power Supply DC 12V power Input
Watchdog Watchdog timer function
Dimension 170mm x170mm
>> I/O Ports
HDD 2 x SATA2.0 ports up to 3Gb/s
SSD 1 x mSATA Connector (by BIOS setup)
Serial Port 4 x COM ports (3 x RS232 + 1 x RS232/422/485)
Audio Realtek ALC886 HD Audio Codec
Keyboard/Mouse N/A
LAN 1 x Intel I210AT PCI-E Gigabit controller
1 x Intel 82579LM PCI-E Gigabit controller
USB 4 x USB2.0+ 2 x USB3.0
Digital I/O 4-in & 4-out
Expansion 2 x Mini PCIe expansion slots, support SIM card
>> Display
Graphics Intel Integrated Graphics Engine with HD4000
HDMI Up to 1920 x 1200@ 60Hz maximum resolution
DVI-I Up to 1920 x 1200@ 60Hz maximum resolution (Contain VGA signal)
LVDS 24bit Dual channel LVDS,Resolution up to 1920 x 1200@ 60Hz
>> Environment
Operation Temperature 0°~60°C
Humidity 10~90%
下一篇:苏州迅鹏 多功能光伏直流电能表
