传播模型校准用扫频场强接收机
The Coyote is a high performance, modular receiver system providing two unique and independent RSSI measurements using precision dual receivers.
产品分类:无线通信 物联网 仪器仪表 网络层 其它 分析测试仪表 无线通信产品
品牌:产品介绍
详细信息
- 覆盖GSM/CDMA/UMTS/EVDO/WiMAX/LTE等主流移动通信频段
- 高速采样, 满足李氏采样原则
- 内置GPS接收模块
- 内置64MB存储卡, 支持长时间数据记录
- USB连接PC远程实时控制
- 一体化坚固设计, 适合野外工作环境
The Coyote? is a high performance, modular receiver system providing two unique and independent RSSI measurements using precision dual receivers. Coyote? is designed from the ground up to provide hot-swappable components including removable/rechargeable Li-Ion battery, Compact Flash® storage, removable 12-channel GPS receiver module and two removable receiver modules. Optional, GPS-based Forecaster? mapping software makes Coyote? the most comprehensive receiver system available to engineers today.
- Multiple bands supported including Wi-MAX, Cellular, GSM, LMR, PCS, ISM, WCS, MMDS and more
- Dual modular receivers allow users to swap various bands while in the field
- High measurement rate, more than twice that of Dr. Lee''s recommended 40 lambda
- Removable 12-channel/12 satellite GPS modular receiver with active antenna
- Removable rechargeable Li-Ion battery system found on standard PC laptops
- Removable Compact Flash (64MB card included) memory system for data storage
- Captured data output via USB and serial ports for connectivity to any PC
- Optional Dead Reckoning software for use with Blaupunkt''s TravelPilot® DX-V and EX-V models
- Optional GPS-based mapping Forecaster? PC software
- Weighs only 7 pounds fully loaded
- Designed and manufactured in the USA
Chart HALT/HASS试验箱解决方案特点介绍
Chart真空绝热管道
电池管理系统测试平台
动力电池充放电系统
直流马达测试方案
