传播模型校准用大功率信号源
Tortoise is a portable, rugged, high-power transmitter system comprised of dual, independent modules giving the user freedom to transmit on any 2 unique frequency bands simultaneously without the need for expensive and bulky additional transmitters
产品分类:无线通信 物联网 其它 网络层 无线通信产品
品牌:产品介绍
详细信息
- 覆盖GSM/CDMA/UMTS/EVDO/WiMAX/LTE等主流移动通信频段
- 最高输出功率达45瓦(1GHz以下)/25瓦(1GHz以上)
- 输出功率0.1dB步进可调
- 内置高驻波比保护
- 一体化坚固设计, 适合野外工作环境
Tortoise? is a portable, rugged, high-power transmitter system comprised of dual, independent modules giving the user freedom to transmit on any 2 unique frequency bands simultaneously without the need for expensive and bulky additional transmitters. Tortoise features two dynamically controlled Class A amplifiers for the cleanest signal output and VSWR protection. Tortoise features built-in thermal overheat protection circuitry with quad cooling fans to ensure against overheating during operation. Remote adjustments include power level, channel or frequency assignment and transmit On/Off via USB, RS-232 and Ethernet from anywhere. Optional LTE, UMTS, CDMA or WiMAX MODULATORS allow Tortoise? to simulate base station transmissions complete with adjustable step sizes, channel bandwidth and user settable ID Cell, Segment and frame lengths.
- CW module combos include frequencies for CDMA, Cellular, PCS, Paging, ETACS, iDEN, SMR, ISM, LMR, UMTS, GSM, LTE, WiMAX, Wi-Fi, AWS & more
- Optional LTE, UMTS, CDMA IS-95 or WiMAX Modulators for base station simulation (10 Watts output maximum)
- Two independent transmitter module bays
- Power amplifier with continuous adjustable power output ± 0.1 dB over 32 dB range
- Water resistant, rugged 18" x 15" x 6" ABS plastic case
- Microprocessor-controlled with front panel soft-keys or remotely controlled with an internal modem for user programmable modulation schemes, power levels, channels, and frequencies.
- 640 x 240 LCD (1/2 VGA)
- Calibration/Usage intergrated hours meter
- VSWR antenna protection and internal forward and reverse measurement
- Quad cooling fans with built-in thermal overheat protection for amplifier
- Battery backed-up SRAM stores all user selectable parameters in the event of a power loss
- Powered from 110-240 VAC 50-60 Hz
- Weighs under 20 pounds
- All parameters can be adjusted remotely via RS-232 or the internal modem or DTMF signaling tones
- Designed and manufactured in the USA
Chart HALT/HASS试验箱解决方案特点介绍
Chart真空绝热管道
电池管理系统测试平台
动力电池充放电系统
直流马达测试方案
