Modulated Average Power Measurement
The Giga-tronics 80400A Series Modulated Power Sensors let you measure the average power of amplitude modulated, burst modulated and other complex modulated signals, such as TDMA signals - at bandwidths up to 40 kHz. This sensor works with the 8540B, 8540C, 8650A, 8650B series power meters.
产品分类:无线通信 物联网 其它 网络层 无线通信产品
品牌:产品介绍
详细信息
- The Giga-tronics 80400A Series Modulated Power Sensors let you measure the average power of amplitude modulated, burst modulated and other complex modulated signals, such as TDMA signals - at bandwidths up to 40 kHz. This sensor works with the 8540B, 8540C, 8650A, 8650B series power meters.
- The Giga-tronics 80600A Series Modulated Power Sensors provide bandwidth up to 1.5 MHz to measure the peak and average power of CDMA signals. This sensor works with the 8540C, 8650A, 8650B series power meters.
- The Giga-tronics 80701A Modulated Power Sensor provides system bandwidth up to 10 MHz to measure peak and average power of wide band, third-generation CDMA signals over an 80 dB range. This sensor works with the 8650A and 8650B – option 12 required (1 GHz calibrator) series power meters.
Chart HALT/HASS试验箱解决方案特点介绍
Chart真空绝热管道
电池管理系统测试平台
动力电池充放电系统
直流马达测试方案
