CW Power Measurement功率测量
Measure CW power from 10 MHz to 50 GHz at more than 17,500 readings per second over GPIB. Measure up to 90 dB with a single sensor, and sel ect from a variety of high power sensors up to 50 W.
产品分类:仪器仪表 现场仪表
品牌:产品介绍
详细信息
Measure CW power from 10 MHz to 50 GHz at more than 17,500 readings per second over GPIB. Measure up to 90 dB with a single sensor, and sele ct from a variety of high power sensors up to 50 W.
- 80301A Series Standard Power Sensor, +20 dBm to -70 dBm, 10 MHz to 40 GHz
- 80310A Series Low VSWR Power Sensor, +26 dBm to -64 dBm, 10 MHz to 40 GHz
- 80320A Series High Power Sensor, +30 dBm to +47 dBm (1W to 50 W), 10 MHz to 40 GHz
- 80330A Series True RMS Series Power Sensor, +20 dBm to -30 dBm, 10 MHz to 40 GHz
- 81305A Standard Power Sensor +20 to -50 dBm; 10 MHz to 50 GHz, 2.4 mm (m), for 8650B (Opt 12) only
These sensor groups work with the 8540B, 8540C, 8650A, 8650B and 58542 VXI series power meters and the 8003 Scalar Network Analyzer.
Chart HALT/HASS试验箱解决方案特点介绍
Chart真空绝热管道
电池管理系统测试平台
动力电池充放电系统
直流马达测试方案
