2526B系列射频微波信号源
The 2526B Microwave Signal Generator delivers industry-best offset phase noise performance, high output power, and fast frequency switching speeds in a single unit.
产品分类:仪器仪表 信号发生器 分析测试仪表
品牌:产品介绍
详细信息
- 频率范围 100KHz – 26.5GHz
- 最高输出功率 15dBm
- 最快频率切换速度 500us
- 优异的单边带相位噪声指标
- 支持内外AM, FM, 脉冲调制功能
- 支持GPIB, LAN, USB远程控制
The 2526B Microwave Signal Generator delivers industry-best offset phase noise performance, high output power, and fast frequency switching speeds in a single unit. The 2526B Microwave Signal Generators are offered in two different configurations designed for bench top and ATE applications with frequency resolution of 0.001 Hz over the entire band. Loaded with performance features such as high time base stability, frequency modulation (FM), high-speed pulse/square wave modulation (PM), amplitude modulation (AM) and high leveled output power makes it an excellent test solution for a wide range of CW, modulation, swept frequency, and fast frequency switching applications in both R&D and manufacturing environment.
Advanced Synthesizer Technology
The 2500B series Microwave Signal Generator utilizes new Advanced Synthesizer Technology that delivers excellent close in phase noise performance of -77dBc @ 100 Hz and -96dBc @ 1KHz and an ultra low phase noise performance of -109 dBc @ 10 kHz and 100 kHz offset on a 10 GHz carrier frequency.
Faster to Program
Every 2500B Microwave Signal Generator comes with Giga-tronics Automation Xpress, a PC based software package designed for enhanced user interface and automatic test systems. The Automation Xpress CD includes a full-featured plug-and-play driver and soft front panels to provide the ATE system integrator with everything needed to get up and running fast. A comprehensive LIST mode, Command-Line interpreter with script and loop capability, and GPIB traffic monitoring are just a few of the many features a test system programmer will appreciate when developing and debugging Test Program Sets.
- Frequency range: 2 GHz to 26 GHz
- Output power: +13 dBm at 50 GHz
- +10 dBm with Step Attenuator option at 50 GHz
- Standard Low Phase Noise
- -109 dBc/Hz at 10 GHz and 10 kHz offset
- Ultra-low close-in Phase Noise option
- -90 dBc/Hz at 10 GHz and 100 Hz offset
- -70 dBc/Hz at 10 GHz and 10 Hz offset
- High Stability Time Base for outstanding frequency accuracy
- 0.001 Hz frequency resolution
- Excellent Spectral Purity
- Harmonics < -55 dBc
- Sub-harmonics < -60 dBc
- Spurious < -58 dBc
- Phase Modulation
- Rate 100 Hz to 100 kHz
- Peak Dev 10 rad-pk/N
- Pulse Burst mode
- 1 to 300 pulses/burst
- Set pulse width, rep rate and burst period
- Electronic Attenuator option (2508B only)
- 110 dB range
- Power Boost mode option
- USB and Ethernet LAN interface
- Emulation Modes, now standard on all 2500B series Microwave Signal Generators (not all of the commands are available)
Chart HALT/HASS试验箱解决方案特点介绍
Chart真空绝热管道
电池管理系统测试平台
动力电池充放电系统
直流马达测试方案
