无线应变测量系统(Wireless strain measurement system)
无线应变测量系统由无线应变传感器节点、网关、计算机采集处理软件组成。无线数字信号传输方式消除了长电缆传输带来的噪声干扰,整个测量系统具有极高的测量精度和抗干扰能力。
产品分类:无线通信 物联网 仪器仪表 分析测试仪表 其它 网络层 无线通信产品
品牌:产品介绍
详细信息
无线应变测量系统由无线应变传感器节点、网关、计算机采集处理软件组成。无线数字信号传输方式消除了长电缆传输带来的噪声干扰,整个测量系统具有极高的测量精度和抗干扰能力。无线传感器节点采用无线网状网设备,可以组成庞大的网络结构,支持多达上千个测点同时进行大型结构试验。无线应变测量系统被广泛应用于桥梁、建筑物、飞机、船舶、车辆、起重机械在线监测等。本系统采用先进的发射/接收和应变测量设备,便于安装,工作稳定性高,其主要性能指标如下:
- 内置高容量电池.
- 采用低功耗无线mesh模块.
- 高达20KM传输距离.
- IP66设计适用于车载及外场测量.
- 100%程控设置.
- 单个应变设备内置8个应变测量通道,最多可扩展到64个通道.
- 多个应变设备可以串联使用.
- 支持WBK系列信号调理和扩展模块.
- 每个通道有独立的滤波器.
- 1MHz ADC.
- 通道之间的时延小于100ns.
Wireless strain measurement system contains: strain sensor, Wireless Node, Wireless Gateway as well as DAQ software. Wireless digital can offer very low noise which compare with long wired cable, so it provides high accuracy result. This system is using wireless mesh equipment and support up to thousands of measurement points in the same network. Wireless strain measurement system has been widely used in bridges, buildings, aircraft, ships, vehicles, crane-line, etc. The system uses advanced transmitter / receiver and strain measurement module,it is very easy to be installed and maintenance.
- Embedded High capacity battery.
- Low power consumption Mesh module.
- Up to 20KM transmission range.
- IP66 and Industrial grade.
- 8-channels built-in, expandable up to 64 channels per StrainBook.
- Multiple StrainBooks can be synchronized for applications >64 channels.
- 1-MHz scanning A/D converter, with simultaneous sample and hold on each channel.
- 100% programmable, no mechanical pots to adjust.
- Full, half, and quarter arm support.
- 60 to 1000 Ohm bridge.
- Software-selected Shunt-Cal.
- Independent filter per channel.
- Programmable excitation source.
Chart HALT/HASS试验箱解决方案特点介绍
Chart真空绝热管道
电池管理系统测试平台
动力电池充放电系统
直流马达测试方案
