嘉兆科技 9354-1/2阻尼正弦信号发生器
9354-1 & 9354-2瞬态信号发生器,主要为MIL-STD-461、GJB 151A/152A CS116阻尼正弦瞬态传导敏感度试验设计,同时可满足RTCA DO160D Section 22中部分波形。
产品分类:仪器仪表 信号发生器 分析测试仪表
品牌:产品介绍
详细信息
应用:
主要性能描述:
9354-1 & 9354-2瞬态信号发生器可完成六个阻尼正弦瞬态脉冲信号(10 KHz, 100 KHz, 1 MHz, 10 MHz, 30 MHz, 100 MHz)以及三种双指数瞬态脉冲信号(9354-1:6.4 µS, 70 µS, 500 µS; 9354-2:6.4 µS, 70 µS, 120 µS)。
主要参数:
10 KHz
Open Circuit Voltage............................30 V.
Calculated Short Circuit Current........120 A.
Source Impedance...........................<0.25Ω
100 KHz
Open Circuit Voltage..........................300 V.
Source Impedance.............................<2.5Ω
1 MHz
Open Circuit Voltage........................3200 V.
Calculated Short Circuit Current........128 A.
Source Impedance..............................<25Ω
10 MHz
30 MHz
Open Circuit Voltage........................1000 V.
Calculated Short Circuit Current..........20 A.
Source Impedance..............................<50Ω
100 MHz
Calculated Short Circuit Current............6 A.
Source Impedance.................................<50
6.4 µS
Rise Time.........................................100 nS.
Open Circuit Voltage........................1600 V.
Calculated Short Circuit Current........800 A.
Source Impedance.............................<2.0Ω
70.0 µS
Rise Time............................................6.4 S.
500 S(9354-1)
Rise Time.............................................50 S.
Calculated Short Circuit Current........400 A.
Source Impedance.............................<4.0Ω
120 S (9354-2)
Rise Time.............................................40 S.
Weight: 55.0 lbs. (25 Kg)
Size: 17.25" (43.5 cm) wide x 8.75" (22.2 cm) high x 13" (33.0 cm) deep.
可选附件:
9335-2 通用耦合钳
9142-1N 注入探头
9125-1 校准夹具
9123-1N 电流探头
9410-1 50Ω/50Ω高压衰减器
9554-1 600Ω/50Ω高压衰减器
6220-4 高压音频隔离变压器
Chart HALT/HASS试验箱解决方案特点介绍
Chart真空绝热管道
电池管理系统测试平台
动力电池充放电系统
直流马达测试方案
